External Hard Drive Recommendations, please!
Hello,
I really need to buy an external drive. Please advise on brands, and any particular model that people have used and like. I have no experience buying external drives but i need one. Here are my specs: MacBook Pro 2.2 GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 SDRAM Mac OS X 10.5.7 MBox 2, ProTools LE 4.2.something Any advice would be very much appreciated! Thanks! Cheers, aerynn |
Re: External Hard Drive Recommendations, please!
Glyphs are approved, compatible with PTLE, bit expensive but wont give you any problem. PT 4.2???
geez...you should get PTLE 8. Doesnt cost that much and its , the bomb. good luck!!!
MBP 17" 2.4 ghz, 320gb 7200 , 4 GB RAM, Glyph GT050Q, 10.5.7 Mbox2, PT8cs3, BFD2 www.myspace.com/yanncrusoe |
While the majority of people have a preference for a particular brand, that's usually based on simply a couple of good or bad experiences. The fact is that there really isn't much difference between the brands when it comes to reliability. How long a particular drive will last has more to do with luck than anything else (so ignore MTBF ratings - they're completely meaningless). I use an ioSafe Solo which is waterproof and fireproof. It's a bit more expensive than a standard eHDD, but better protects your data.
HTH. |
Go here and select from the right hand column(to get a pair of FW400 ports)
http://eshop.macsales.com/shop/firew...b/eliteclassic
http://oyendigital.com/firewire-usb-...ard-drive.html
http://eshop.macsales.com/shop/firewire/on-the-go Both of these have 7200 RPM 2.5' Drives that are buss powered. Both have Oxford Chipsets. Both will be excellent.
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
+1 for OWC drives from www.macsales.com.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Obsidian Dragon
'nother +1 for macsales and OWC. I have a bus powered FW 800 that has been just fine and convenient for portability
MacBook Pro 2.5GHz Digi 003 Factory / MBox2 Micro 4 GB memory, OWC 750GB HD OSX 10.5.5, PTLE 8 |
Thanks all, I'll review this tomorrow night and hopefully make a purchase.
External Drive Recommendations | AnnexProjekt | macOS | 10 | 10-22-2012 06:44 AM |
External Hard Drive Recommendations | TylerW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-17-2010 04:03 PM |
Recommendations For An External Hard Drive | rmccam | Pro Tools TDM Systems (Mac) | 19 | 06-08-2009 10:03 PM |
Hard drive recommendations | babakdm | Storage Subsystems | 5 | 08-24-2008 08:59 PM |
Recommendations on external hard drives??? | Mr Layz | Pro Tools M-Powered (Win) | 2 | 04-07-2006 11:26 AM |
