Old 01-29-2009, 08:18 AM
fil_mac fil_mac is offline
Exclamation Undesired Frequency... is there any filters for electric power?
I'm having a problem while recording with Protools. Sometimes while im recording, one strang sound (high frequêncy) gets in the microphone. It has something to do with the electric power, that bring harmonic frequencys. Do you guys know any filter that could prevent my microphone preamp to amplify that strang signal? Is there any other solution? Please help me if you can.
Old 01-29-2009, 08:48 AM
barstool719 barstool719 is offline
Default Re: Undesired Frequency... is there any filters for electric power?
try using different mic cables. also check your monitor and usb/firewire cables.
other than that, if youre recording in the same room as your computer, it could be picking up fan noise. if youre using an old CRT monitor, it can cause interference.
if its a power problem, look into a power conditioner, and check the grounding in the building.
kinda hard to say for sure what it is, or exactly what to try without hearing the noise.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 01-29-2009, 09:23 AM
Ken Burk Ken Burk is offline
You probably don't want to use a filter unless the audio is already done and can't be re-recorded. I've tried to remove a 60 Hz hum that was repressive from a live event. Results were only tolerable.
MacBook Pro 2.5GHz
Digi 003 Factory / MBox2 Micro
4 GB memory, OWC 750GB HD
OSX 10.5.5, PTLE 8
Old 01-29-2009, 09:35 AM
I´m sure it is cause by electric interference, because i tried to turn off some engines (like the elevator or the water pump and it spoped. The electric engenier told me that must be some FM frequency that is amplified by the mic preamp. By how can i filter the electric power?
Old 01-29-2009, 10:37 AM
stainless stainless is offline
Do you have light dimmers on any of the room lighting? Dimmers (unless those made specifically for sound stage/theatre) are notoriously noisy
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 01-30-2009, 01:45 AM
My voice boot ligths are leds. I've decided to use leds because of the noise. So shouldn't be the ligths... i guess.
Old 01-30-2009, 09:55 AM
DrFord's Avatar
DrFord DrFord is offline
I would venture they posters are right and it is your lights. If the problem went away when you turned off motors, then you really need to get a seperate breaker or power system installed. Pro Studios usually have a seperate system where the Orange wall outlets are studio gear only and the regular are for everything else.
You can do what I did and buy a monster power center. I have the pro 7000 and it specifically filters for clean power. Works great for me.
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Strange frequency while recording... is there any filter for the electric power? fil_mac Pro Tools M-Powered (Win) 2 02-05-2009 01:16 AM
Pop Filters & Top End Equality 7-2521 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-16-2006 04:48 AM
OT: Pop filters... storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-04-2004 06:31 AM
Undesired effects with Digi002 Rack andrej770 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-15-2003 08:51 PM
Pop Filters Silence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-19-2002 01:36 AM
