What\'s equivalent of 85 db on a Master Fader 002?
I've been reading about how mixers/engineers prefer to monitor and tweak tunes at @85 db. What's Pro Tools equivalent when you are monitoring mixes by looking at the Master Fader track? I have been doing most of my work at 0.0 db on the master fader. I know virtually nothing about this subject, so please advise....
Jay
**JAY TERRIEN** BASS ~ VIOLA ~ ARRANGEMENTS With Artists STEVIE WONDER, MOBY, RIHANNA, ESPERANZA SPALDING, RANCID, JOSH GROBAN, ALIEN ANT FARM, ANDY GRAMMER, THE BODEANS, FRANK OCEAN, PAT MASTELOTTO (KING CRIMSON, XTC, THE SUGARCUBES) etc. E-mail: [email protected] http://www.reverbnation.com/JAYTERRIEN http://www.facebook.com/JAYTERRIEN http://www.twitter.com/JAYTERRIEN http://www.myspace.com/JAYTERRIEN http://www.jayterrien.com/home.htm |
Re: What\'s equivalent of 85 db on a Master Fader 002?
That's 85dB out of the monitors.. depending on the gain of your amp or powered monitors.. it'd be different for everyone. In all my years - I've really only seen one engineer calibrate the monitor pot for 85dB... except when setting up for a film mix with Dolby.
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
So there's no real way for me to tell right? It's not like I want to monitor at ear splitting levels but as I am going back through and carefully piling through some muddy mixes that have virtually no clarity, I figured I'd try and get at least the volume level basics down.
This 85db stuff really applies to cinema and mixing for cinema - but, to let you know, it refers to a specification whereby each channel is calibrated such that pink noise at reference level
corresponds to -20dbvu = 85dbc. Its just part of a calibration spec. |
Else, you could just guesstimate it. I don't think there's anything magical about the 85-db SPL figure.. as long as you're monitoring at a moderate level, you should be okay. Try this- if you can carry on a conversation with another person in the room while mixing without yelling, you're probably mixing at a reasonable level. I tend to vary my listening level while mixing, to see how it sounds at different levels. Doug |
Thanks for the quick suggestions boys.....
Yep, get youerself a Rad Shack meter, the analog one. The very same meter than Bob Ludwig uses....
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master Fader 6.7 Master Fader issues | Bogner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2005 07:42 AM |
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? | Ricky Cobble | Pro Tools TDM Systems (Mac) | 5 | 05-05-2003 04:47 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
