Re: Fix phasing with nudging?
interesting thread.
You are a good man Daniel. I wondered how long it would take someone to point that out. Also, thanks for the example. I found it rather interesting. |
-Duardo |
-Duardo <hr /></blockquote><font size="2" face="Verdana, Arial">... and that button has shown to be slightly buggy too. Best regards, Haigbabe
Drive fast, take chances |
For those who say phase and timing are the same thing, try this simple experiment:
Copy a track and paste its contents onto an adjacent track; use the audiosuite 1-band EQ to reverse the phase (or "polarity") of one of the tracks; zoom in to the sample view and compare the two. They are different, and no amount of nudging will make them identical. A simple way to understand the real-world effect of phase (or polarity) is to think of a speaker. If a pair of monitors are wired with opposite polarity, a mono signal center-panned will cause one cone to project out while the other "sucks" in. Again, a timing adjustment won't change this. Take care, Glenn |
Jeez, folks, please get your terms straight. That button you refer to is marked with a phase symbol, but actually it changes the POLARITY of a signal by making a negative voltage into a positive voltage of equal but opposite value and vice versa (i.e. for a baseline of zero volts, a signal swing of negative 1.23 volts is turned into a positive 1.23 volts when the polarity button is pushed). That is polarity. You are correct, it does nothing to the timing relationships. Your speaker example is an example of polarity change.
PHASE helps describe a time vs. frequency relationship between two signals. Put the same mono soundfile on two tracks and move one of the tracks relative to the other by any tiny amount you like, say one or two samples. Combine the two tracks through your mixer to one speaker. You will very likely notice a change in the sound, but that change probably will be perceptable only with higher frequencies. The lower frequencies, while time shifted the same amount, will be affected to such a small degree that they add together nearly perfectly and you will probably hear no quality difference whatsoever between a single track and the combination, except the combination may sound louder. The higher frequencies are affected more, so they do not all add together perfectly, thus there is a perceived change in quality. Put two mics in front of a snare drum, start hitting the drum, and move one of the two microphones. The time it takes for the snare drum sound to get to the moving mic changes. The snare is picked up by both microphoes, and individually they might even sound identical. But combine them together in your mixer and your will hear phase problems, and this problem will be most apparent as the microphone continues to move. Different frequencies will be affected in different ways because the phase relationship at each frequency is different. What you are hearing is generally called comb filtering, which is the direct result of different amounts of phase change at different frequencies, caused by the moving microphone changing the time relationship of itself to the drum, relative to the other mic to the drum. Clear as mud. Apples are not oranges and phase is not polarity. I left my watch at home.
Call me by my real name, "Postman" |
the terms polarity and phase invert have been pretty synomimous in this industry for ever. 180 degree phase shift is a polarity invert. don't get your feathers in aruffle, this topis was trashed to death months ago.
Hope this is helpful. |
Yes, people say one when they mean the other, which leads to a misunderstanding of what the differences are. There is rampant misunderstanding in this thread about what phase is, and what the difference is between phase and polarity, leading to misinformed statements, which perpetuates the problem even more. And THAT can cause people to try to solve their problems by applying ineffective techniques. Apparently the topic, perhaps beaten to death, has fallen on more deaf ears.
Can phasing problems be solved by nudging? Some of them, yes! If it sounds better after nudging than before, then you fixed it! Same goes for the polarity button (marked with a phase symbol), but polarity change and phase change via nudging (or any other time-shift method) are not the same thing at all. I am "back quiet".
Mic Phasing | Murt | Tips & Tricks | 11 | 01-23-2010 10:59 AM |
Phasing? | -Mikael- | General Discussion | 4 | 04-16-2007 03:10 PM |
Phasing | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-14-2005 07:25 AM |
phasing? | Locash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-25-2003 04:43 PM |
HOW DO I STOP PHASING ? PLEASE HELP ! | Pete Weaver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2002 08:14 AM |
