  #21
Old 01-31-2023, 12:02 PM
James Steele's Avatar
James Steele James Steele is offline
Default Re: EUCON 2022.12 Released
I know the Artist series is not officially supported, but I would be thrilled if a fix for the screen color issue in the Artist Control made its way into that release. I know Avid isn’t obligated to do so on unsupported hardware, but I can dream! :)
M1 Max Mac Studio, 64GB/2TB, macOS 14.5 Public Beta, DP 11.31, Pro Tools 2024.3.1, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Avid S3, Console 1
  #22
Old 01-31-2023, 12:18 PM
EddieJones's Avatar
We are looking into whether its possible and will try our best.
  #23
Old 01-31-2023, 01:45 PM
Originally Posted by originalscottyg View Post
I've only tested for a short time after installing the update this morning. But this update seems to be working well for me, other than one weirdness with a particular custom shortcut not working.
I have Back and Play mapped to the non-shift layer RTZ button on the Dock, and that's working fine. I have Play Edit Selection Start mapped as a key command to the shift layer of the RTZ button. The keyboard shortcut is cmd-opt-left arrow. This worked previously in 2022.9. I had backed up my custom soft keys and have tried restoring my back up as well as deleting and recreating the custom shortcut, but it still doesn't work. It works fine using the same key commands on the keyboard.
Mac Studio M1 Pro
macOS Monterey 12.5.1
Pro Tools Ultimate 2022.9 (could this be the issue?)
EuControl 2022.12.0.81 / 4.10.2.81
Dock + 3 x S1 + iPad + 3 x Fire 10 HD
HDX/Sonnet Echo III-D
MTRX Studio
Thanks to Nathaniel Reichman's suggestion on the FB group, this is fixed. The solution was to remove EuControl and MC_Client from Security& Privacy->Accessibility, log out (reboot in my case) then add them back in. That worked a treat and all is working for me again!
Scott Gatteño
  #24
Old 01-31-2023, 02:29 PM
SKI's Avatar
SKI SKI is offline
Originally Posted by EddieJones View Post
We are working on fixing and doing a 22.12.1 dot release with a couple of other small things too.
Thanks, this is all we could expect or hope for.
It's a shame how you only realize the true value of something when it's missing.
The EUCON workflow is definitely something that falls into that category.
URBAN MUSIC-
(Hip Hop and R&B)
  #25
Old 01-31-2023, 04:18 PM
That's all anyone could reasonably ask for. Thanks so much, Eddie!
  #26
Old 02-01-2023, 08:27 AM
Baze Music Baze Music is offline
Hi, I've been having the same problems with a few more issues. I have an S1 and Dock. Sometimes the S1 drops off now and it takes a bit of trial and error to get it back. Re connect power and Ethernet cable and re-start Eucon apps a few times usually brings it back. Also I noticed it's ahving weird affects on any other program that might be open like Firefox or Chrome. This never happened before.
I tried the above solution adn it did not work for me.
mac Pro 2019 os 11.7.1 Pro Tools Ultimate 2022.12.0, was on PT 2022.10 and thought updating would help, but same issue persist.
Mac Pro 7.1 Big Sur 11.7.1
Pro Tools Ultimate 2023.3.0
UAD Apollo X8
Avid Dock and Avid S1
  #27
Old 02-01-2023, 08:50 AM
EddieJones's Avatar
If this is just the S1 can you switch the power and ethernet with the Dock and see what happens?
  #28
Old 02-02-2023, 11:31 AM
Funny, after I posted this. the S1 is working fine.
When/If it starts again I'll swap the cables.
UAD Apollo X8
  #29
Old 02-02-2023, 02:28 PM
seanob99 seanob99 is offline
With the dock I've always used the wheel for clip gain and assigned that to a button on the right. Since the update I have to click that button a couple times to get the wheel to respond. I would not have updated but my one of the tablets had auto update on and I had the version mismatch.
  #30
Old 02-03-2023, 08:22 AM
EddieJones's Avatar
I just tried this on my PT/EUCON 22.12 system and it works OK. On mine its User 1 (shift) Can you post a video of this?
EUCON 2022.9 Released EddieJones Avid S1, S3, Dock and Control App 18 02-28-2023 08:12 AM
EUCON 2022.12.1 Released EddieJones Avid S4/S6 42 02-06-2023 05:39 PM
EUCON 2022.9 Released EddieJones Avid S4/S6 4 09-27-2022 08:09 AM
EUCON 2022.4 Released EddieJones Avid S1, S3, Dock and Control App 17 05-08-2022 07:26 PM
EUCON 2022.4 Released EddieJones Avid S4/S6 0 04-29-2022 03:32 PM
