Re: Since yesterday , my focusrite 2i2 won't have any insert.
Tried the sound card from my work macbook, no issue, laptop on Yosemite...
Should I just re install Sierra or get Yosemite? |
Back on El Captain 10.11.6, back to normal
OK cool. Since Focusrite claim the 2i2 works on Sierra you should follow up with them before you try to upgrade again. With some irony that Sierra seems a much better OS for many users than El Capitan.
I kinda want to put sierra back, but since the last update messed it all up, I really dont want to play with it, was so painful
From Focusrite (after had gone back to El Capitan, so haven't tried this...
"We just started seeing this odd issue with the release of the newest Sierra update, 10.12.2. In this new update to OS Sierra the Scarlett Solo, 2i2 and 2i4, are showing up as two separate devices, one for Input and one for Output. Thus in DAWs where you select the Scarlett you are only able to use Inputs or Outputs, but not both, resulting in either no Input or no Output depending on which you select. We have a work around for now, but we are looking into a better long term resolution. Please open the Applications > Utilities > Audio MIDI Setup. Press the small + sign to create a new Aggregate Device. In this new Aggregate Device add both the Scarlett 2i2 Inputs and Outputs. Then select this Aggregate Device in your DAW. This should allow you to use both Inputs and Outputs of the Scarlett until we find a better fix for this issue."
PT 2021.12.0 w/Focusrite 2i2 iMac i7 3.8GHz / 72GB RAM / Mac OS X 12.1 https://linktr.ee/sergius128 |
HW Insert Delay for Focusrite Saffire 56 | Dot | Pro Tools 10 | 0 | 08-28-2012 10:29 PM |
Focusrite Saffire and PT 9 Hardware Insert Help!! | Obe1 | Windows | 3 | 06-14-2011 03:02 AM |
Focusrite ISA 428 balanced insert send and return | tripstation | General Discussion | 4 | 01-02-2010 12:51 PM |
Since yesterday I have this certain bug ... | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-01-2003 04:59 PM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
