My Mackie Woes
Well, this is a bit off topic, but I wanted to see if anyone here could help me out.
I've got a Mackie 1402VLZ-Pro mixer and I'm trying to create headphone mixes from the two Aux sends. I'm only using the 4 stereo channels to make these mixes. I'm getting plenty of signal for a good headphone mix. But One problem, it's only in the left side! I read in the manual that for some purposes you can actually send the left signal with Aux 1 and the right signal with Aux 2. Now, that seems sort of dumb to me, but whatever. The idea is that a mono signal should come out from these outputs, so why is the signal only in the left headphone? Now, I'm sort of a rookie to all this, but the only logical explanation can be found in the signal 'conversion'. You can take a stereo signal, and by connecting only the left side, it will be come mono. But In my case, I'm taking a mono signal and putting it into a stereo source, my headphones! So I guess my question is: what the hell is going on? I want a mono, or hell even better, a stereo signal from the Aux send 1 and 2. But now that I know that you can't get a stereo mix from a mono output, how can I get the signal to be in both outputs of my headphones and not just in the left. Does anyone understand me?! Thanks for any advice! - Andy |
Re: My Mackie Woes
Use the mono inputs.
www.barnabas.com Barnabas MultiMedia |
Re: My Mackie Woes
because the mono jack on your 1202 only contacts the left input (tip) of the headphone connector. The right input (ring) is either grounded out or floating. Get a 1/4" stereo to mono adapter from Radio shack. make sure that the male end of it is mono. That will ensure that you get the signal to both sides.
Re: My Mackie Woes
Well, I'm using the mono inputs for preamps into my system. So that's my problem. But even if I did use those mono inputs, that still doesnt explain why I'm getting a left-only signal form the AUX out! [img]images/icons/confused.gif[/img]
- Andy |
NI woes | cp2 | Virtual Instruments | 1 | 01-08-2008 10:53 AM |
URS N12 woes | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-07-2004 07:13 AM |
My Mackie Woes | spicyitaliano | General Discussion | 3 | 06-06-2003 08:38 AM |
My Mackie Woes | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-05-2003 12:50 AM |
a note from Mackie about the Mackie control | remote | Pro Tools TDM Systems (Mac) | 100 | 11-02-2002 12:25 AM |
