Re: Izotope Insight
Not from what I have been reading. It's all going to be based on the program loudness.
Re: Izotope Insight
I like it but find it annoying that the loudness history resets when you close the plugin window during playback. I use windows configs to open and close stuff like that constantly during a mix and need the history to stay running in the background. Hopefully they fix it.
Re: Izotope Insight
There is both bs 1770-1/2 in insight. DMm is bs 1770-1 in the version I have.
From what someone else said here, Europe is using Lufs while the ntas is still using Lkfs as the standard. What that means in terms of using 1770 1or 2 I don't know. Insight metering is just a difference in how the meters display values. Peak/rms is Dbfs |
Re: Izotope Insight
So this was my question on another thread, with CALM coming shortly, no specs were given to anyone I know. As currently, -24 LKFS +/- 2 is the standard, 1770 -1, what is the calm spec for the US? Is it still -24 +/-2 but 1770-2? When I run my mixes at 1770-2, they are usually 1.5 LU's more than with 1770-1. So if the magic number is -24, then I need to turn the mix down and the room up. Luckily, my series is on a pay channel, so they don't have to follow the CALM act as far as I know. But if I jump on another series that is, I'd like to start getting my references correct. thanks |
Re: Izotope Insight
Just a heads up. If you're running the trial version, don't close the session with it active. On relaunch of the session the authorization window will put PT into an unrecoverable state.
Had to force quit, had a kernel panic, and restart and rebuild session by importing tracks. I guess this would make me buy it quicker. |
#16
Re: Izotope Insight
Danijel Milosevic |
#17
Re: Izotope Insight
#18
Re: Izotope Insight
#19
Re: Izotope Insight
Probably no way around that. But I highly recommend to turn off automating Insight while not mixing.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#20
Re: Izotope Insight
That might stop it. |
FS: Protools 8 HD also Izotope Insight | TVPostSound | Buy & Sell | 3 | 04-19-2016 09:06 AM |
Izotope RX3 Advanced upgrade include Insight ?? | vudoo | AAX Plug-ins | 3 | 09-25-2013 10:39 AM |
