Re: Ethernet port 2
Frank,
One small detail about using Artist Series units on port 2: After connecting the Artist unit to port 2, did you try a restart of the computer? After a restart the EUCON prefs should recognize your unit on port 2. I realize you're up and running via port 1, which is great, but if you get a chance to try again on port 2, then restart, then check the EUCON prefs let me know whether it works. I'm the Technical Writer at Avid who is (now) responsible for all Artist series documentation, and I apologize for this info not having made it into any of the manuals (it only came to my attention after I'd finished the last round of updates). This info should have been added to the KnowledgeBase but I don't see it there either...I'll work to correct that as well. Michael Avid Consoles Principal Technical Writer |
Re: Ethernet port 2
And also a section how the system preference EuCon thingy is set up. I dragged the PT app icon into the prefs but it can only be set to either HUI or MackieControl. Do I need to do this for PT at all? What do I set it to? Lots of guessing going on when setting up these controllers, I must say. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Ethernet port 2
I have a similar requirement I want to connect the C24 to the second ethernet port and just have my normal LAN traffic on the first port, is there a config setting somewhere as I can only connect to a single ethernet in the setup drop down list.
Thanks in advance. |
Re: Ethernet port 2
Re: Ethernet port 2
Thanks for getting back to me Eddie. I watched the video and that is exactly what I expected to happen. The second Ethernet port was installed after PT and Ethernet was renamed to Ethernet1. I expected PT to then populate the dropdown list with the new ports. It would seem that PT has not rescanned the interfaces, is there a way to force a rescan?
Here is the Network screen and the select dropdown in PT (hope you can see the images, the links seem to work but my windows machine does not see the images). Btw. the machine has been rebooted a couple of times but no joy. Thanks again. |
#16
Re: Ethernet port 2
That's strange I agree. Could you try something.....change the subnet mask to 255.255.255.0 and reboot the Mac and see if that helps. Not sure why you need that mask so open.
Also, switch the order of 1m and 2 and see what happens if the first thing doesn't work. |
#17
Re: Ethernet port 2
I have changed the Ethernet order, reduced the mask and rebooted as suggested, (255.0.0.0 is just the default for the 10. Class C private subdomain), neither action makes any difference. This is as if PT has scanned just once when it installed, as it has retained the original name. I do not really want to un-install PT just to rescan the ethernet ports. Is there a config file that can be edited or deleted to force a re-scan?
Thanks |
#18
Re: Ethernet port 2
I think PT scan on opening the prefs. Try disabling port 1 and see if it goes...then you will know
#19
Re: Ethernet port 2
I removed the cable from Ethernet1 and made the interface inactive in the Network preferences. Restarted PT and the same Ethernet (without the number) still in the PT dropdown. This time I also started up wireshark, normal IP traffic is on Ethernet2, but nothing that co-insides with PT scanning. When I repeat this with Ethernet1 re-enabled I see a broadcast packet when searching Ethernet from PT. I come to the same conclusion, PT does not rescan the interfaces after installation. Something is not being updated in PT?
#20
Re: Ethernet port 2
hi Eddie, Could you try a quick test, rename your Ethernet port name using the Network preferences, then see if PT picks up the new name. Btw. I am on PT12.4.
Artist Control v2 -PC with 1 ethernet port | Swurveman | Artist Series | 2 | 05-07-2012 02:22 PM |
Ethernet port #1 not working / lighting up | RhodesB3 | Aspera DigiDelivery | 1 | 02-23-2012 03:35 AM |
MC Control Ethernet port issue | RuffinMedia | Artist Series | 2 | 02-03-2011 04:44 PM |
Enable Ethernet Port For Pro Control? | RT60 | Pro Tools TDM Systems (Mac) | 6 | 10-26-2007 03:32 PM |
C24 Ethernet port quit.. please help! | Surth | ICON & C|24 | 1 | 07-22-2006 04:34 PM |
