Older TDM systems and FW Hard Drive sizes.
I might be completely wrong, but I think I remember hearing that there is a to the size limit for Firewire hard drives used with older Pro Tools systems (001 and Mix/24 era.)
Is that true? I heard the limit was between 60 and 80GB |
I use a TDM mix cubed system running PTs 5 on Mac OS 9. I'm able to see 160 GB FW drives without issue. I'm able to record 24 tracks of audio onto those drives without partitioning. I can't remember but I thought the limit was 250GB. I've never tried anything higher than a 180 GB seagate in a Lacie d2 case. |
Re: Older TDM systems and FW Hard Drive sizes.
the limitations has nothing to do with PT, but with the IDE controller. the older ones can see HD over 127 GB.
on mac, there's a little extention, called ATA Hi Cap that allows old controllers to see bigger HDs... FYI, "older controllers" means G4 quicksilver and olders. The "new" ones came with the G4 MDD series. When it comes about a firewire or USB drive, well, hard to know...if it's an old FW or USB bridge... except if you bought after... let's say...2004 ? |
Hard Drive Backup Systems | ammusicco | Pro Tools TDM Systems (Mac) | 11 | 03-12-2010 12:50 PM |
Switching Systems and hard drive died.. how can I get my PT back? | 2A Batterie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-05-2008 07:30 AM |
Older DSP cards with MIX systems | thepurpleroom | Pro Tools TDM Systems (Mac) | 1 | 02-18-2008 03:17 AM |
Older pro tools systems? | mixerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-04-2005 08:08 AM |
Older 001 systems -> xp 5.3 | keny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-17-2002 11:45 AM |
