Audio Glitching in PT 2021
I recently upgraded to PT 2021 on my Mac - and now, when I insert audio from certain sources, I'm getting artifacting and little pops that AREN'T there on the recording, but show up when I put the audio into ProTools.
It only happens with SOME audio - stuff I've recorded myself, and one other VO person I've come across so far. Everything else seems totally fine. I'm running PT2021 on Mac Monterey OS, but was having zero issues with it before. I tried increasing the buffer size, and that didn't help. Any suggestions? |
Re: Audio Glitching in PT 2021
The other day I began scheduling Chronosync to create backups every 30 minutes due to a SSD failure and I've begun noticing that the playback glitches every time I get the Chronosync completion notification. This doesn't explain why the previous glitches occurred but perhaps its a background process that causes it. Part of me suspects certain combinations of plugins too. Still experimenting to try to find the cause/solution. Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2 |
But lets start with when you say "insert audio" what exactly do you mean? Do you mean import an MP3? there appears to be issues in 2021.10 with MP3 imports causing click and pop artifacts. That's discussed on other threads you can find on DUC by searching... best to search using Google with a site: duc.avid.com qualifier. If not importing MP3 then *exactly* what are you doing, with what format files, what interface, sample rate etc. If ignore errors is checked then uncheck it and leave it unchecked. Do you see the pops/clicks in the audio wave form or not (I assume yes if the above issue). If not it's something else. Still stuck, start at "help us help you" up the top of every DUC web page. Make sure your systems is fully optimized, yes even if it worked perfectly OK before and start as with all troubleshooting by trashing prefs, then test starting with new empty sessions. And if not that then it's possibly plugins. Try removing all .aaxplugin files from the plugin folder and repeat in a test session. Last edited by Darryl Ramm; 12-02-2021 at 05:39 PM. |
Profile/SC48 - Glitching sounds in recorded audio | gsguitarest | VENUE Live Sound Systems | 0 | 10-22-2019 04:05 PM |
Mac Pro + HD PCIe + Bootcamp + Windows 7 = extreme glitching and unusable audio | omm | Pro Tools HDX & HD Native Systems (Win) | 4 | 05-25-2015 09:26 AM |
Severe audio glitching issues with MBox 2, makes playback unbearable. | AliGlenUig | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-08-2011 03:39 PM |
Audio Glitching | blastula | Pro Tools TDM Systems (Mac) | 2 | 09-13-2010 11:16 AM |
PTIII audio glitching | David Wright | Pro Tools TDM Systems (Mac) | 11 | 08-06-2003 10:44 PM |
