Old 09-29-2010, 07:09 PM
Dr Scary Dr Scary is offline
Default Where is "delete unused regions" now (LE8)?
It used to be that I could click the drop down menu on the regions list on my earlier protools but now on LE8 I have to select each file from the list. It won't give me an option for the unused. Can I not do that now? Thanks in advance!
Old 09-29-2010, 07:25 PM
anothercolour anothercolour is offline
Default Re: Where is "delete unused regions" now (LE8)?
It is still there under the Region List Menu.
First delete unused Playlists, select Unused under Select in the Region List Menu, then choose clear.
how to delete unused regions shabbar3 Pro Tools 9 1 04-21-2013 02:44 PM
KB shortcut to delete all "old" regions in a session? Hercules Pro Tools 9 1 09-21-2011 05:10 PM
Delete unused regions!!!!! Musicb4hw Tips & Tricks 6 02-23-2006 12:36 PM
"Delete Unused Regions" is not available JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-14-2003 05:24 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
