Lo-Fi Crashes Pro Tools
Hi I'm Running into a really showstopper bug.
I'm having a mix session with alot of different plugins and everything is great. But when the session is mixed and I close it, and then re-open it, I get a dialogue saying it can't activate around half the plugins because of insufficient system ressources. I'm not using half of the dsp available and as soon as I try to activate a plugin I get a DAE #1 error (and sometimes a #7401 error). And if I then try close the session Pro Tools crashes. When trying to solve it I found out that I could make a new session, import everything from the old one and it works again, but as soon as I save it and re-open it, the same story... I the found out that it seems to be the Lo-Fi plugin that causes all this. If I keep it de-activated everything works great. But as soon as I activate it, it breaks the session after re-opening it. I'm only running one instance of lo-fi. All plugins are as TDM. I tried to reinstall the lo-fi plugins without result. I have also tried to trash pro tools preferences etc. without success. Anyone experienced something like this and now of a fix? I have been using it several times without any issues. It just started happening this week and nothing has been changed on the computer. The system is a Pro Tools HD2 74.cs5 on a Powermac G4 |
Re: Lo-Fi Crashes Pro Tools
http://www.digidesign.com/index.cfm?...51&itemid=1009 bottom of the page the 4th one down.. D-Fi 7.4 (Mac OS X Tiger - Leopard) for Pro Tools 7 25.85 MB
Yep. Have the version for 7.4 installed & Verified
Those DAE errors can be indicative of a bad card.
Have you tried running Digitest yet? |
I also ran a digitest with no errors at all.
I'm in process of mixing some cartoon episodes. And I had mixed around 14 sessions, and then after doing this for 2 weeks, all of a sudden it started to do this. The setups in the session has been exactly the same.... The only difference is that the new sessions has been recorded on a digi003 system running PT 8. But I only imported the audio, not the plugns or anything else. (import session was set to import: main playlist, regions & media, alternate playlists & markers) |
after trashing all the prefs i would manually remove the D-FI plugin from the plugins folder system drive/library/app support/digidesign/plugins. Then i would repair permission from disk utility. Then reboot the mac. then re-install D-FI. then boot up PT and see what happens. Just to be sure! this is happening on all sessions, NOT just one, in which case it could be session corruption of some kind. Chris
Hi Crizdee.
I tried all that. It's not happening on all sessions. But on around 4-5 sessions. First I also thought it was a corrupt session, so started from scratsch with a session, but it then started to do it again |
When you manually remove then from the plugins folder! make sure you remove all 4 individual plugs. lo-fi.recti-fi.sci-fi etc
Hi crizdee.
Also tried that without any difference.... And thanks alot for your help so far, it's really great how much you're trying to help me resolve it! |
8 Pro tools crashes in 1 day?!!? | iamnightfall | macOS | 21 | 09-26-2013 03:01 PM |
Mac OS X 10.6.2 crashes with Pro Tools 8 | NikoNewYork | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-06-2010 11:40 AM |
Pro Tools 8 Crashes | Hudson Handel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-05-2010 10:33 PM |
Pro tools 8.0 crashes out of no where | chrono4548 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-03-2009 11:45 AM |
Pro Tools CRASHES my PC | XyberICE | Digidesign Hardware & Software | 4 | 05-07-2005 03:44 PM |
