Old 02-03-2017, 03:04 PM
MARVINBASS's Avatar
MARVINBASS MARVINBASS is offline
Default PT 12.7 and Sierra not seeing my HDX Card!!
I have a Mac Pro Mid 2010 that was just running fine with OSX 10.10 Yosemite and PT 12.6.1 yesterday.
Well I decided to update to Sierra 10.12.3 and PT 12.7--- When I first launched Pro Tools it kept crashing trying load all my plugins. Once I sorted out which ones were stopping the launch process, I finally get to an assertion error. I checked my hardware and it now does not see my HDX card and of course my interfaces. I even installed the HD drivers thinking that maybe in this version you had to install it. Nope nada!!!!
I assume that PT.7 needs a firmware update to the card but it never came up. Please Tech Support enlighten me what I'm missing here.
My System is:
Mac Pro 3.2GHz 6 Core
32GB RAM
1- HDX
1 - Apogee Symphony Mk2 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
Second System
Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2
32GB RAM
1 - HDX
1 - Avid Thunderbolt 3 Expansion Chassis
1 - HD 8X8 Interface
MARVINBASS Digital Audio, LLC
Ex PT Beta Tester
Woodland Hills, CA.
Old 02-04-2017, 11:22 PM
MARVINBASS's Avatar
Default Re: PT 12.7 and Sierra not seeing my HDX Card!!
Wow!! no one wants to help!! Where's Avid Tech Support???
BTW I restored my previous OS and PT 12.6.1 and everything is WORKING AGAIN. So don't ask me to move the HDX card to a different slot it's not that!
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 02-04-2017, 11:43 PM
JFreak JFreak is online now
Not here. Try this.
Old 02-05-2017, 12:58 AM
MARVINBASS's Avatar
Not here. Try this.
Yes I will do that. Thanks!
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 02-05-2017, 09:54 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Im assuming you do have the Digilink I/O authorization?
IMDB
Old 02-05-2017, 10:07 AM
Drew Mazurek's Avatar
Digilink started with 12.6, so it can't be that.
www.drewmazurek.com
Old 02-05-2017, 11:37 AM
MARVINBASS's Avatar
I double checked my iLok and I do have the DigiI/O asset. Thanks for trying. It would have been the obvious solution, but 12.6.1 in Yosemite was running great. I have a case opened to Tech Support. Let see what gives. Have a Great Weekend and Super Bowl Sunday!! CHEERS!
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 02-05-2017, 11:39 AM
MARVINBASS's Avatar
I had PT 12.6.1 and Yosemite running great. I do have the Digilink I/O asset.
My System is:
32GB RAM
1- HDX
MOTU MTP/AV
Second System
32GB RAM
1 - HDX
Ex PT Beta Tester
Woodland Hills, CA.
Old 02-05-2017, 06:29 PM
Wawili_Sound Wawili_Sound is offline
I have same problem with windows 10, protools 12.7 HD native card. 12.6 and 12.7 work but only with 12.5.2 HD driver. 12.7 has access violation errors though when opening a new workspace or saving session. So looks like its back to 12.6 with 12.5.2 HD driver. Man this sux balls.
WIN10 12.6 HD Native, Omni, BlackLion XB192
Old 02-05-2017, 09:50 PM
propower propower is offline
Was the ProTools install in 10.10 and then you upgraded to Sierra and 12.7? If so that may be the issue. When changing to a newer OS I always start from a clean OS and then PRoTools install. Get everything working and carefully add plugins making sure all are current revisions.
Running 12.7 and 10.12.3 with Sonnet chassis and HDX1 here - only the normal issues -9173 and out of CPU a couple of times per day. HArdware is all fine - Waves, Fabfilter, Lexicon, Valhalla, Toontrack, plugin alliance - all working fine.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
HDX with PT non HD on Sierra ? JJdelRio Pro Tools HDX & HD Native Systems (Mac) 14 04-26-2017 07:47 AM
PT 12.7 Sierra 10.12.2? off the wall macOS 2 01-17-2017 01:49 PM
Can't get Sierra on 5,1 Mac Pro Carl Lie Pro Tools 12 21 01-06-2017 04:46 PM
HDX and Sierra Jeffrey Talbot Pro Tools HDX & HD Native Systems (Mac) 5 11-16-2016 03:21 PM
OSX Sierra jack s. macOS 25 11-05-2016 04:51 AM
