Buffer overload -6085 error constant
Hi I have just bought a MBOXPRO with protools 10.
I have it installed in a mobile workstation Dell M4500 Precision with Intel Quad Core i7 @1.73 GHz. I have 8 MB in RAM Memory and an external USB 1TB HDD. Windows 7 , 64 bit. I have tried everything to solve this error but it constatly appears when recording a new track or even just playback. Its really anoying and I cannot record a single clip!!! Can someone can help? Thanks |
So u really Need to post to Sandra report for system specific information
You can find that on one of the links that say help us help you or read this first whatever it is And I would definitely ask you a bout what your playback engine is set up at ? what your buffer is set up at ? and what your hard drive speeds are? all of those things would be answered by Sandra report but that's where I would personally start looking
Re: Buffer overload -6085 error constant
SiSoftware Sandra
ID Host Name: mess-PC Workgroup: NOVA System Model: Dell Precision M4500 Serial Number: 1NW **** System Chassis: Dell Laptop Folding Main Card: Dell 041WH1 Serial Number: / 1NWL3Q1/CN1 ************ System BIOS: Dell A06 11/20/2010 Total Memory: 8GB DDR3 SO-DIMM Processors Processor: Intel (R) Core (TM) i7 CPU Q [email protected] (4C 8T 1.86GHz/2.93GHz, 2GHz IMC, 4x 256kB L2, 6MB L3) Connector / Slot: FC PGA988 Chipset Memory Controller: Dell Core (Clarksfield / Lynnfield) DMI 2x 2.4GHz (4.79GHz) Memory controller: Intel Core Mobile (Clarksfield) Uncore 2x 2.13GHz (4.26GHz), 2x SO-DIMM 4GB DDR3 1.33GHz 128-bit Module (s) from memory Memory Module: Kingston 9905428-073A00LF 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module: Kingston 9905428-073A00LF 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video system Monitor: BenQ GL2230 BNQ [bleep][bleep](1920x1080, 21.7 ") Monitor: Generic PnP Monitor LGD (1600x1200, P727R € 156WD1 , 15.3 ") Video adapter: NVIDIA Quadro FX 1800M (48 SM4.1 1.13GHz, 1GB DDR3 1.58GHz 128-bit, PCIe 2.00 x16) Graphics processor Compute Shader Processor Type: NVIDIA Quadro FX 1800M (48SP 1.13GHz, 1GB DDR3 1.58GHz 128-bit) Physical storage devices Seagate ST9500420AS (500.1GB, SATA300, 2.5 ", 7200rpm, 16MB Cache): 466GB (C :) (D :) ST1000DM003-9YN162 Seagate (1TB, USB2/SATA600, 3.5 ", 7200rpm): 932GB (F :) HL-DT-ST DVD + /-RW GU40N (SATA150, DVD +-RW, CD-RW, 1MB Cache): N / A (E :) Logical storage devices RECOVERY: 11GB (NTFS) PROTOOLS (F :): 932GB (NTFS) @ Seagate ST1000DM003-9YN162 (1TB, USB2/SATA600, 3.5 ", 7200rpm) READER (D :): 2GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5 ", 7200rpm, 16MB Cache) OS (C :): 453GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5 ", 7200rpm, 16MB Cache) CD-ROM/DVD (E :): N / A @ HL-DT-ST DVD + /-RW GU40N (SATA150, DVD +-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1: Dell LPC Interface Controller QM57 LPC Legacy Controller 1: T0 00-00 Audio Device: Dell P55/PM55/3400 High Definition Audio Audio Device: Dell High Definition Audio Controller Port (s) Series: 2 Port (s) parallel: 1 Disk Controller: Dell Mobile SATA RAID Controller Disk Controller: Dell PCIe SD / MMC Host Controller USB Controller 1: Dell P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2: Dell P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1: Dell FireWire Host Controller Controller CardBus / PCMCIA 1: Agat-RT CardBus bridge System SMBus Controller 1: Intel ICH SMBus Printers and Faxes Printer: Nuance Image Printer Driver (600x600) Printer: Microsoft XPS Document Writer (600x600, Colour rendering) Printer: HP psc 1600 series (1200x1200, USB, Colour rendering) Fax: Microsoft Shared Fax Driver (200x200) Printer: Canon MF4100 Series UFRII LT (600x600, USB) Printer: Canon MF4100 Series (FAX) (400x400, USB) Printer: Brother PC-FAX v.2.1 (200x200) Printer: Brother MFC-9840CDW Printer (600x600, Colour rendering) Printer: Adobe PDF Converter (4000x4000, Colour rendering) Scanners and Cameras Digitizer (Scanner): Brother MFC-9840CDW LAN (Digitizer (Scanner), 1200x2400, USB) Thanks, I have tried to change different parameters on the playback engine (buffer size, etc.) Right now I have the following: Buffer size: 64 Processors: 4 CPU limit: 90% Buffer transmission plug in level 2 size I have the internal HDD @ 7200 where the protools software is installed, I also have an external USB HDD @ 7200 RPM where I am saving my sessions. Here is the Sandra report Many thanks Network Services Network Adapter: Intel (R) 82577LM Gigabit Network Connection (Ethernet) Network Adapter: Bluetooth Device (Personal area Network) (Ethernet) WiFi Wireless Adapter: Intel (R) Centrino (R) Ultimate-N 6300 AGN (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Battery # 1: Sanyo DELL HVHC012 93.24Wh/7.35Ah System (s) operation (s) Windows System: Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance: x64 Windows Experience Index Current System: 5.9 |
make sure you're cores are not parked..Just a thought
http://www.youtube.com/watch?v=pl3u9eiskM4 |
What's the error code say online ? I don't remember - ur Sandra looks fine
thanks mikey, I tried but I still get the same error
your CPU should go up to 99%.Before your song loads in go to the menus up top and see if you can increase it.Also set your processor to one less than what you have available.So if you have 8 set it to 7...Also have you done all the optimizations
http://avid.force.com/pkb/articles/e...411?popup=true |
I agree the Sandra report looks great. Call it a hunch but but I'm curious about DPC Latency. You should disable any networking whether wired or wireless and check for DPC spikes. And as mentioned you need to do the required optimizations to get off on the right foot.
DPC Latency Checker
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Thanks,
I followed all the steps for optimize my computer. However now Protools does not recognice the MBOX.. I will reinstall protools and drivers to see what happends. Thanks |
constant CPU error overload!!! | clintusmaximus | macOS | 1 | 12-06-2012 04:17 PM |
Constant CPU Overload and DAE 35 Error | AlissaAudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2012 03:49 PM |
-6085 buffer error | themick7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-11-2008 04:18 PM |
Constant H/W Buffer Error message (help me) | TekNeek | Pro Tools M-Powered (Win) | 3 | 11-14-2006 11:25 AM |
How to SOLVE CONSTANT BUFFER ERROR | blendthis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-29-2005 01:20 AM |
