Old 06-22-2022, 02:37 PM
j dub j dub is offline
Default Cpu usage
I am trying to get back into recording music again now that I I have some time away from work. Unfortunately I am running into CPU / AAE -1973 issues with very minimal plug ins in my session.
Attached is a screen shot of the CPU usage with the session "idle". Why is CPU usage at 100%
I am running a 2013 MacPro 10.14.6
3.5 GHz 6-core Intel Xeon E5
64GB 1866 MHz DDR3
I am using an Apollo 8 as my interface. Weirdly it seems like plug ins in the Apollo console cause the CPU monitor in Pro Tools to be affected briefly but they are using DSP from the UAD Apollo 8.
Would love any guidance. Thanks.
File Type: png Screen Shot 2022-06-22 at 5.20.49 PM.png (21.9 KB, 0 views)
Old 06-23-2022, 08:19 AM
daeron80 daeron80 is offline
Default Re: Cpu usage
That can happen if your buffer setting is very low. 32, for instance.
Have you gone through the suggestions on this page yet? Are all installed plugins up-to-date (whether or not they're instantiated in the session)? Are the Apollo drivers up-to-date? Is your OS compatible with your PT version?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-23-2022, 10:36 AM
you left off the most useful info... exact macOs version? and exact Pro Tools version?
If you are still stuck after trying standard troubleshooting, come back here and describe your setup and what you are doing in more detail, including session sample rate, IO buffer size and what exact troubleshooting you tried and what exactly happened.
In addition to not trying to run at tiny IO buffers sizes as David pointed out (should be no reason if you are monitoring through the Apollo Console) always start troubleshooting by trashing prefs, get Pete Gates free PT Prefs utility to make that easy.
You say using minimal plugins in your session...so there are some instantiated in Pro Tools? not just the Console. They might cause issues, especially if UAD plugins and you have a small IO Buffer, or it can actually be any installed plugin that has some problem, you don't even need to be using it, just have it installed in Pro Tools, which is why doing an early test of moving *all* .aaxplugin files out of the plugin folder is such a great diagnostic test.
Total PT System Usage: CPU Usage at 100% with Nothing Running TMNTfan Pro Tools 2019 11 11-28-2019 04:34 AM
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
CPU usage error?! System usage 2%... pascalmowla Pro Tools 12 3 03-10-2016 12:00 PM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
