MTRX Studio+DVS playback engine
Current Setup: Mac Pro with HDX card, MTRX Studio, Dante Virtual Soundcard, Pro Tools Ultimate
I normally just run my Mac Pro with HDX card via Digilink, and have Dante/DVS hooked up between MTRX Studio and Mac Pro. However I was curious about a possible scenario and how to get by in a pinch: if the HDX card is unrecognized or otherwise incapacitated. I know it's possible to use DVS as the Playback Engine, but how do I properly incorporate the I/O of the MTRX Studio in this case? For example, if I currently have a mic preamp that is patched analog in to a channel on the MTRX Studio (which normally is routed into PT via HDX/Digilink), can I route it via Dante into 1 of the 8 available inputs in Pro Tools, when PT is using DVS as the playback engine? When I go to I/O setup I see 8 inputs/8 outputs, but not sure how to patch into those inputs. Thanks! |
Re: MTRX Studio+DVS playback engine
It would just be a case of routing everything through Dante rather than digilink I/O. It can be a bit of a mind bender, as there are three separately places you need to route audio:
- DADman routing matrix only routes audio between the inputs and outputs of your MTRX Studio, relative to the MTRX Studio itself. The Dante Outputs go to Dante Controller. - Dante Controller routes audio between the various Dante ports present on the network, like your MTRX Studio and DVS. - Pro Tools I/O menu routes audio internally in Pro Tools. To setup your inputs, - In DADman route your analogue inputs to the appropriate Dante outputs. - In Dante Controller, route the appropriate MTRX Studio transmitter channels to the appropriate DVS receiver channels. - In Pro tools, select the appropriate inputs in the I/O menu. To set your outputs, - Configure them in your Pro Tools I/O menu output tab. - In Dante Controller, router the appropriate DVS transmitter channels to the appropriate MTRX Studio receiver channels. - In DADman, create a new source in your monitor profile and select the appropriate Dante input channels. Then it is just a case of hitting the appropriate monitor source button in the monitor section. Sticking to 1 to 1 routing throughout will make it much clearer (Analogue in #1 to Dante out #1, #2 to #2, etc, etc).
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 08:48 AM |
HD Native Thunderbolt Engine is not being retained when selected as Playback Engine | antonis | Pro Tools HDX & HD Native Systems (Mac) | 0 | 01-08-2022 01:07 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
Playback Engine Issue (Won’t load session with chosen playback engine) | MattyJones | Pro Tools 11 | 0 | 11-02-2015 11:52 AM |
No m-audio interface in current engine (playback engine) | SlicerSounds | Windows | 1 | 10-04-2012 12:27 AM |
