Anyone Used Imation Floppy For PACE Authorizations?
Just going from my 9600 - G4 and wonder it the Imation Floppy with get it done. Not talking about the Imation Superdrive but the currently available Floppy Drive.
Thanks |
Re: Anyone Used Imation Floppy For PACE Authorizations?
Hi
As for Imation you would need to use the Superdisk only. So your options are VST Floppy Drive (model FDUSB-M) Imation SuperDisk NewerTechnology uDrive Note: Information on VST brand products from SmartDisk has been moved to www.smartdisk.com |
Huh?
I have an Imation USB floppy drive; it ran all the authorizations just fine. |
I have and recommend the Imation USB Superdisk/Floppy.
"AE": So you have just the Imation Floppy and and not the Imation/Superdrive and it works? We are just getting ready to get a new G4 and have an Imation Floppy (NOT Superdrive) and were hoping this would work. No problems?
Mac Pro 3.5GHz 6-core (6.1 2015) Monterey 12.6.8 64 GB RAM 1 TB PCIe flash storage Pro Tools Ultimate HD 2023.6 HD Native Thunderbolt |
It depends on the internal machanism iMation was using at the time. I have seen the regular imation floppy work on occasion (not often), but its not reliable.
Also, I've seen some of these "nonsupported" drives (like Teac, etc) be able to install authorizations, but NOT be able to remove them. |
Doh! I've just bought a TEAC floppy before realising that there might be any compatibility problems. I can't find the info saying that the Teac drive won't work. Does this mean my Teac USB floppy can't be used to authorise/de-authorise my plug-ins? What will happen if I try and use it?
Regards, Mike |
Well, so far I've used the Imation floppy drive for just one round of authorizations (when I upgraded to an 867 MHz G4 last September). That's certainly not sufficient experience to generalize from. I'll post again if I run into any problems.
I did the exact same thing: Moved from a 9600 Mac to a G4/733. I used the Imation USB floppy drive (not the super) and it worked fine. Also used it to install stuff on my Powerbook G4/500. Worked fine there as well. My assistant used it on his G4/500 tower and it worked fine there too. I moved stuff like McDsp, Virus, Koblo, Digi, TC etc. BUT...
ONE IMPORTANT THING: You must go to the PACE site and download the USB FLOPPY ENABLER file. This makes your drive work first time every time. My floppy was cranky before we downloaded and installed this file. It creates an extension by the same name. Once I was done with installs, I disabled this extension just for grins. I think the PACE site is www.paceap.com. If not do a google search on PACE Anti-Piracy.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor |
The Teac drive Might work for you. I'm just telling you what I've seen. Usually with some tweaking I could get it to authorize, but there were times I could not get it to de-authorize.
If you just bought the Teac, then you can probably swap it for the VST fdusb-m model... $50 And Digi can't list every device that WON'T work. Do you know how long that list would be? Again, my point is, that these "unsupported" drives might and do work sometimes.. its just kind of a crap shoot. |
Floppy Authorizations to ilok | CHRIS AIKEN | Pro Tools TDM Systems (Mac) | 2 | 03-02-2005 07:52 PM |
old floppy authorizations with ilok, what to do? | digigirly | Pro Tools TDM Systems (Mac) | 2 | 09-08-2003 10:02 AM |
floppy authorizations on G4? | didger | Pro Tools TDM Systems (Mac) | 9 | 07-20-2003 12:37 AM |
Imation USB floppy drives; Good? Bad? Indifferent! | Heaven | Pro Tools TDM Systems (Mac) | 5 | 06-11-2003 05:44 AM |
HELP with Imation super Disk and 800k Authorisation floppy | the exploding boy | Pro Tools TDM Systems (Mac) | 1 | 01-07-2001 12:10 AM |
