  #21
Old 09-21-2023, 01:37 PM
marianna's Avatar
marianna marianna is offline
Default Re: 2023.9 is here!
Originally Posted by Adam Venn View Post
Does anyone have more information on what slewing is please?
From the documentation........
Slewing helps audio and video to stay in sync when there is no common clock reference between audio and video hardware. However, it can be problematic in certain circumstances, such as with loop playback. This sewing option lets you keep longer playback passes in sync, while maintaining performance during loop playback.
HTH
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #22
Old 09-21-2023, 01:41 PM
Adam Venn's Avatar
Adam Venn Adam Venn is offline
Venn Audio
Thank you for the response, Marianna. Do you have any more detail? I will find myself needing to explain to people why changing that setting won't help some unrelated problem. I'm happy to read some technical documentation on the principle if it exists.
  #23
Old 09-21-2023, 01:47 PM
off the wall's Avatar
off the wall off the wall is offline
HD Driver 2023.9 is exhibiting the same AAE Error -6001 on PT launch as did the pulled HD Driver 2023.6 version. Reverting back to HD Driver 2023.3 with PT 2023.9 is working fine.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #24
Old 09-21-2023, 01:59 PM
zeeman zeeman is offline
Hey Marianna,
Sorry if i missed that. I dont recall that conversation.
thx for keeping this alive. Much Appreciated.
Chris z
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
  #25
Old 09-21-2023, 02:31 PM
dawelsch's Avatar
dawelsch dawelsch is offline
Originally Posted by marianna View Post
Dave
Are you on 10.14.6 Mojave?
Looking at the case - OS was missing but it did show that in the attached log.
Marianna
Yes, Marianna. I missed that field. Sorry.
Mojave 10.14.6
Dave Welsch
Bassist|Educator|Producer
www.DaveWelsch.com
  #26
Old 09-21-2023, 02:32 PM
Note that along with 2023.9 there is a new 2023.8 installer for the Air Instruments Bundle. No I have no idea where release notes are for that bundle. There was a mention of a bug fix for Boom (old Boom UI appearing in a specific situation) that was mention in the Pro Tools 2023.9 release notes, and Boom does not seem to have been updated itself.
Anyhow here are the plugin version comparison I see on Mac between AIR Instrument installer bundles 2023.8 and the previous 2023.3, only Xpand!2 seems to have changed. (edit: no not a new structure... I had goofed and was looking at the prior version from previous installer.)
Code:
           2023.8                     2023.3
Boom       1.2.11.c91d897 Universal | 1.2.11.c91d897 Universal
DB-33      1.2.11.7db087e Universal | 1.2.11.7db087e Universal
MiniGrand  1.2.11.7db087e Universal | 1.2.11.7db087e Universal
Structure  1.5.11.6e53130 Universal | 1.5.11.6e53130 Universal
Vacuum     1.2.11.7db087e Universal | 1.2.11.7db087e Universal
Xpand!2    2.2.11.ce75b63 Universal | 2.2.11.78f793e Universal
Edit: Oh and there is a new PlayCell 2023.9 Mac (ZIP) 113.54 MB. Missed first time, I hope others don't miss these updates.
I'm editing my plugin spreadsheet at https://docs.google.com/spreadsheets...it?usp=sharing updating for this release. And realized that should include all plugin versions numbers as well so I'll add those eventually. At least then there will be a reference to check the latest install against.
  #27
Old 09-21-2023, 02:51 PM
IrelandM IrelandM is offline
2023.9 Installed.
To Darryl Ramm,
Can your google doc spreadsheet be altered or is it read only.
Regards
  #28
Old 09-21-2023, 03:00 PM
BarneyBarry BarneyBarry is offline
Also for me selection and all gui works way better on windows
  #29
Originally Posted by IrelandM View Post
2023.9 Installed.
To Darryl Ramm,
Regards
You can let me know of errors/suggestions or if you want I can give you edit privileges if you have a Google account or can help you make a compete editable copy and you can do whatever you want with it. What I can't do is mark a copy editable by everybody with the link.
I just changed it from "reader" to "comment" for everybody, so noting mistakes etc. is easier. I though I had set that before.
  #30
Old 09-21-2023, 03:12 PM
ejsongs ejsongs is offline
I Hope they fixed the issue of ara melodyne losing data when session is saved. I had to revert back to 2023.3 because in 2023.6 I had several instances where I had to répitch entire vocals. I hate having to redo stuff that I had already done.
Ej
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
Pt 2023.9 Rectifried Pro Tools 1 08-31-2023 01:00 AM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 02:29 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
