Old 09-29-2022, 05:52 AM
jsbach jsbach is offline
Default Can 2022.9 be installed alongside older versions?
I can't find the post, but I thought I'd read a comment where someone implied that 2022.7 couldn't be installed alongside older versions of Pro Tools like in the past.
I'm currently on 2022.6. Can anyone confirm if it is still safe to make a duplicate of the current version when updating to 2022.9? I'd like to be able to go back to 2022.6 if there is a problem.
Thanks!
Old 09-29-2022, 06:10 AM
its2loud its2loud is offline
Default Re: Can 2022.9 be installed alongside older versions?
Thanks!
Yes, if you’re on a Mac you can install multiple versions.
Before you install the other version you need to rename the version you currently have installed. So in your case you might rename the application Pro Tool 2022.6 in the Applications folder. Then you can install 2022.9
Old 09-29-2022, 06:47 AM
Perfect. Thank you for confirming!
Old 09-29-2022, 08:21 AM
itsjustmeee123 itsjustmeee123 is offline
I don’t know if this is the right way but it works fine for me. On my Mac I just go into my apps folder, rename pro tools to something like “pro tools 7” and then just install the update.
Monterey now running well on an old 5.1 Cheesegrater alongside older OS Ru_C macOS 1 03-06-2022 05:25 AM
Are older versions available for install? DWprod Pro Tools | Intro Discussion 1 04-30-2020 06:49 AM
Older PT versions and OS X 10.9 digitalpan macOS 1 03-13-2015 01:43 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
Older versions available? adhali Digidesign Hardware & Software 1 11-30-2003 11:13 PM
