Confused about how delay compensation works on aux vs. master fader
I send all of my tracks to an aux called “mix bus”
the “mix bus” aux sends to Out 1-2 I have a few UAD plugins and Pro-L 2 on the “mix bus” aux track. On the aux track the delay compensation is 8839 and the 'dly' indicator has turned red. The manual says that the maximum delay available is 16,383 samples at 44.1/48 kHz My session is 48 kHz. If 16,383 is the maximum delay, then why is 8839 making my aux's dly indicator red? What confuses me even more is that I tried moving all of the plugins off of the aux and onto the master fader. That fixed the problem. After removing the plugins and placing them on the master fader, the "mix bus" aux turned green again. The master fader's dly indicator now reads 8839, but it is orange. Why is the exact same delay amount showing as orange on the master fader, but red on the aux when using the exact same plugins? I'd really appreciate if anyone can help me understand the logic here. I reread the delay compensation chapter in the manual and I am still confused. I don't see any mention of aux and master fader's behaving differently in regard to delay compensation. |
Re: Confused about how delay compensation works on aux vs. master fader
Pro Tools version? Native? HDX? Interface? IO Buffer size?
Delay comp on the master fader/output? Which other outputs have signals going places? If there is one output/Master Fader, delay comp can't do anything to compensate for latency on it, it can't make your signal travel back in time. Orange latency indicators just means the track is the highest latency in the session A "few UAD plugins"... and some UAD plugins can have horrendous latency. So be careful there. And again what IO buffer size are you running at... And you are using an Aux without a live input, so AFAIK it's going to operate in the high latency/large fixed IO buffer domain, assuming you are running native (non-HDX). This is likely the root of your problems. So why do this with an aux? Just send track outputs to a mix bus. KISS. And then play around with a trivial test session and ADC. |
AFAIK, latency on a master track is not compensated for(by design)
Just advice for working with ADC, but look at your plugins and what latencies info the vendors document (UAD documents this very well), and see if what is being reported in Pro Tools is what you expect.
I've already mentioned UAD plugins potential high latency (for their upsampling and lookahead based plugins) and the often inherent need to run large IO buffers to support UAD plugins... but you also mention FabFilter Pro-L 2... a limiting plugin with potentially very high latency. And if running at those high latencies not something you are going to compensate for, its intended to run on the output uncompensated. |
Apollo Twin IO buffer size - 1024 Thank you for explaining. I realize that I wasn't using common sense when thinking about the master fader's delay compensation. It didn't initially occur to me that there is no delay compensation on the master fader by design. It makes sense now that I think about. I was taught to put all of the mix bus processing on an aux instead of the master fader. Mostly because of the master fader being pre-insert. So, I never have any plugins on the master fader. All of my tracks end up at a final mix bus aux. That makes me wonder. If you only have one master fader in your session, couldn't you just always disable delay compensation on the master fader will no issues when mixing? If I have no plugins on the master fader, could I safely just disable delay compensation on the aux that I use for mix bus processing? That way high latency plugins would never be an issue? |
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
True. Master Fader is not a normal channel, it just gives you extra control on outputs. Can insert post-fader plugins, can manipulate levels. That is it. No delay compensation. Master Fader means output point of a mixer, whether internal (buss) or external (physical output). Everyone should understand this concept and if not, learn about it.
Whatever is your master output (as in you print it or listen to it) does not need compensation.
The red indicator led me to feel like I'm doing something wrong which triggered all of this overthinking. Thank you for taking the time to help. I appreciate it. |
Delay Compensation on Master? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2011 12:10 PM |
Delay Compensation + Master Track | twix | Pro Tools 9 | 10 | 08-27-2011 03:52 PM |
Can you disable Delay Compensation on Master? | AINSLIE | Pro Tools TDM Systems (Mac) | 7 | 02-15-2008 09:56 AM |
Confused by delay compensation documentation | jstaczek | Pro Tools TDM Systems (Mac) | 3 | 10-22-2007 08:01 AM |
Auto delay compensation and busses......confused | 2fly | Pro Tools TDM Systems (Mac) | 2 | 01-17-2005 04:26 PM |
