Old 11-02-2021, 09:34 AM
jsbach jsbach is offline
Default random characters when typing plugin name into search box 2021.10
When I type the name of a plugin into the search box the characters are often all jumbled/random. Has this happened to anyone or can you think of a possible cause?
I'm on MacOS 11.6
Pro Tools 2021.10
Any help would be appreciated. Thanks!
Old 11-02-2021, 09:58 AM
persen persen is offline
Default Re: random characters when typing plugin name into search box 2021.10
Same here!
Happens sometimes.
MacBook Pro M1 (13-inch, 2020)
16 GB RAM
PRO TOOLS STUDIO 2022.5
UAD Apollo 8p + Twin Solo + Octo Satellite
Old 11-02-2021, 02:32 PM
Originally Posted by persen View Post
Same here!
Happens sometimes.
Glad to hear I'm not the only one!
It doesn't always happen, and I can't figure out what triggers it.
Old 11-02-2021, 03:51 PM
I tried just now.
I typed cla and som strange symbols turned up
File Type: png Skjermbilde 2021-11-02 kl. 23.48.24.png (69.5 KB, 0 views)
16 GB RAM
Old 11-03-2021, 03:34 PM
I tried just now.
I've had no luck trying to figure out why it's happening. Can't just be us, right? I'll post back if I find a solution!
Old 11-03-2021, 04:01 PM
I see strange characters on 2021.10.0 on macOS 11.6 (Big Sur). It only seems to happen to me on the first character I enter in the search field after clicking on a new insert. And if I keep typing the characters all get sorted out. [edit: removed incorrect observation after more testing].
But I don't get strings of bad characters only the first one is bad and then it corrects as I type addition characters. Weird.
Old 11-03-2021, 04:06 PM
Here is the corruption I see when typing lowercase "x" as the first/only character.
File Type: jpg Screen Shot 2021-11-03 at 4.02.05 PM.jpg (47.0 KB, 0 views)
Old 11-05-2021, 09:45 AM
Originally Posted by Darryl Ramm View Post
I see strange characters on 2021.10.0 on macOS 11.6 (Big Sur). It only seems to happen to me on the first character I enter in the search field after clicking on a new insert. And if I keep typing the characters all get sorted out. It seems like (but not totally sure) if I do this once an insert on a track then click on find for the other inserts on that track it works OK, but clicking on find for inserts on other tracks still show the problem until I do this once for on that track. Do other folks see those behavior?
It's really strange because it seems random for me. Today I can't make it happen, even on the same words that made it happen yesterday.
Old 11-06-2021, 02:51 PM
I was curious and spent more time playing with this. I moved all plugins out of the plugin folder, trashed all prefs and I still get the behavior with the first letter that I type into insert search... field sometimes being corrupted (a significant fraction of the time maybe somewhere around one quarter of the time?)
It does not seem to matter which first letter I type, I can get the first displayed letter mess I described before, but always if I keep typing other letters the display corrects itself. So that's different than others describe. And it's seems to be trying to search for the letter I typed not the garbled letter that is being shown.
I've also seen more behavior where sometimes the search list displayed is missing the first item. Like if I bring up search and type just the letter "a" then the normal first item in the list shown should be "Autopan (Mono/Stereo)" but at different times that item is just missing and the list starts with "ACDC Tapping (Synth Lead Hard)". This seems to be independent of whether the first letter is corrupted, so seems like there are multiple issues with this whole thang.
Again Big Sur 11.6 running Pro Tools Standard 2021.10.0
Old 11-14-2021, 07:52 AM
eduy eduy is offline
I have same issue, they appear and after a couple of seconds i press another key and the correct name shows.. cant find the solution
Random CPU spikes in Pro Tools 2021.10 on M1 Rico618 Pro Tools 1 10-29-2021 01:10 PM
003 console LCD random characters-Help baranger1 FireWire & USB Audio Interfaces (Win) 3 12-31-2018 08:34 AM
Random Graphic Characters in Audio Regions - PT TDM 6.2.3 ChrisMitchell Pro Tools TDM Systems (Mac) 4 05-21-2008 11:25 AM
Channel Matrix and Keypad typing double characters (!?) beggehorn ProControl, Control|24, Command|8 15 08-15-2007 09:52 AM
random search results in the DUC test tube AUDIO General Discussion 1 09-26-2005 07:22 AM
