Why the Elastic Audio errors when i'm only using X-form?
I'm using quite a bit of elastic audio in a song, but all of it is using the 'rendered x-form' setting.
Every now & then i get the "Processing cannot keep up with Elastic audio blah blah.." Error.. How is this so? I thought using X-form, meant none of it was being stretched in realtime?
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
Re: Why the Elastic Audio errors when i'm only using X-form?
<bump>...nobody else ever get this error?
Yes, that's odd indeed, and you're correct, on render-mode tracks, one shouldn't expect to use much Elastic Audio processing resources. The only possibility might be if you have really tight edits - is it over a densely edited section? Does it happen randomly or in a particular place in the session? What does your Elastic Audio CPU meter read in the system window? And does it happen with 8.0 if you've got it available? There were a few Elastic Audio engine fixes in that release. Also, does it happen on other computers?
Cheers, Paul Vercellotti Avid Engineering |
Differences between X-Form Plugin & X-Form Elastic Audio? | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2010 08:51 AM |
HELP - Elastic audio x-form bug on PT 8.0.1 and above | crisjohnnieb | Pro Tools TDM Systems (Mac) | 0 | 12-28-2009 10:49 AM |
Problem with Elastic Audio (X-form) | Greeno | Tips & Tricks | 7 | 04-16-2009 10:43 AM |
Elastic Audio and X-Form need help | D Pinder | Pro Tools TDM Systems (Mac) | 6 | 05-23-2008 06:24 PM |
Elastic Audio X-Form limited | tj_davies | Post - Surround - Video | 0 | 11-12-2007 09:45 AM |
