Old 05-26-2008, 10:24 AM
joe bloggs joe bloggs is offline
Default Unknown Error
Hey wats up with youse,having a small problem with P/T at the moment,this occurs when i go to open a seperate audio program(while running P/T),eg Reason,Cubase,Winamp.it comes up with "UNKNOWN ERROR" without any code.(this is also true when i open Reason first followded by a second program).However if i open Reason in rewire mode it works fine.Im using the Mini 7.4,ive checked the specs on it but i cant figure out if it can handle Audio from 2 seperate programs(excluding Rewire) any tips would be welcome! f
Old 05-26-2008, 10:41 AM
French links French links is offline
Default Re: Unknown Error
The problem is simple...Your hardware is already in use!Thus you can't open two applications in the same time, using the Digi hardware.The only other solution is to use your on board or third party sound card with the other programs than Protools.
Reason Unknown Error, C++ Error, Plug-ins Inactive Paul_Cantor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-20-2009 09:54 AM
Unknown Error. joe bloggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-29-2008 01:30 AM
Unknown error sean1986 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-11-2005 06:30 PM
Error #- 5000 while verifying your Authorisation Unknown Error Help!!! Kitch Pro Tools TDM Systems (Mac) 10 08-12-2003 08:57 AM
Unknown Error bsarvis Pro Tools TDM Systems (Mac) 1 04-25-2002 05:17 AM
