  #21
Old 05-27-2021, 10:50 PM
seanmccoy seanmccoy is offline
Default Re: Premiere Pro AAF to PT
Just imported an 8+ Gb AAF file from PP to PT today to score and mix a 2 hour, 20 minute doc. Perfect on all fronts, including both rendered and raw files from the editor's session.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
  #22
Old 05-28-2021, 12:52 AM
Sonopolis Sonopolis is offline
So this was an embedded or a referenced AAF? What were the export settings?
  #23
Old 05-28-2021, 06:50 AM
tom_lowe tom_lowe is offline
People who know what they're doing!
  #24
Old 05-28-2021, 07:27 AM
Well, after I spelled it out for the editor explicitly. It was embedded, and here are the instructions I sent him:
Mixdown video: unchecked
Use tape sources when present: unchecked
Breakout to Mono: check
Render audio clip effects: check if you've done any of that
Include clip copies without effects: check if you're exporting audio clip effects
Sample Rate: 48k
Bits per Sample: 24
Preserve media directory name: Won't be available when you choose Embed Audio
Format: Broadcast Wav
Render: Trim Audio Files
Handle Frames: 120
HTML code is On
OMF/AAF from Premiere Mitch Griffin Post - Surround - Video 8 12-13-2013 09:00 AM
Help with Premiere Andy A Post - Surround - Video 3 11-10-2006 01:58 PM
Pro Tools and Premiere. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2006 11:20 AM
5.3.1 conflict with Premiere veck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2003 06:03 AM
DC-30+, OS 9.2, Premiere 6.0, QT 5.x Lee Blaske Pro Tools TDM Systems (Mac) 7 08-17-2001 12:03 AM
