Old 06-24-2011, 03:09 PM
tim carter tim carter is offline
Default Issue with going from 48K session to 96K
When I go from a 48K session to a 96K session, I have to quit PT's in order for it to clock correctly from my Rosetta 800, which I am using as my master clock... I get clicks and pops if I don't. Has anyone had this happen?
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8
http://carterbrothersband.com/studio.cfm
Old 06-26-2011, 08:40 AM
Default Re: Issue with going from 48K session to 96K
surely I don't have to quit pt's to go from a 48k session to a 96k session. Is this a pt's issue or is this what is supposed to happen?
Old 06-27-2011, 12:59 AM
Mt.Everest Mt.Everest is offline
Are you using the Apogee XHD cards (or whatever the name is)? Dunno if this is of any help, but I would always crash my system if I didnt follow these steps when changing sample rates using a Rosetta along with a 192 i/o:
Have current session open with its sample rate locked (say 48k)
In Session Setup Window, change clock to " internal " (obvs only on a mixed system)
Close 48k session
Change Sample Rate on Rosetta to new session rate (96k)
Open dummy session with nothing in it, and change Session Setup Sync to receive from Rosetta 96k. (Some plugins like TL Space seem to cause issues when expecting a certain sample rate conversion for the IRs)
Close dummy, open 96k session.
Seems like a lot, but in practice not much. Haven't gotten to my new rig much yet to test with PT HD 9, but on PT7.4, PT did NOT like having its external clock change from a 3rd party device, jumping between sessions.
Hope that helps in the troubleshooting at least.
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 06-27-2011, 01:43 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I'v also have problems syncing PT9 (MboxPro) with my Black Lion Microclock MKII at 92 and 192 kHz.
Result is that I stopped using the microclock.
I have to switch forth and back between internal and word clock many times (3-4 times) befor it syncs.
Also there is a nasty clicking noise when switching between internal or word clock at 96 and 192 kHz.
Seems to work fine at 44kHz tho.
Opening a Session Issue RichrdC Pro Tools M-Powered (Win) 1 08-02-2011 10:30 AM
The last measure of a PT session issue. HELP !!!! Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2007 05:43 PM
6.4 session issue audio1420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-30-2004 01:42 PM
G5 to G4 session exchange..is there an issue??? soundmatters Pro Tools TDM Systems (Mac) 1 05-12-2004 11:45 AM
G4 001 Session > G5 002, Clockspeed issue lambro3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-02-2004 04:03 PM
