Old 09-02-2002, 05:21 PM
dBgogogo dBgogogo is offline
Default CD Offset Frames
Offset frames - how many are you using and why?
Masterlist defaults to 15, and I've been using that without problems.
But I'm about to send a disk off for replication, and wanted to get some feedback first. Thanks!
Old 09-11-2002, 01:42 PM
Randy Bryant Randy Bryant is offline
Default Re: CD Offset Frames
15 should be fine. If I remember correctly the offset is for players that may unmute too late when randomly positioning to a new track. It mutes, positions, then unmutes. If the the offset is not long enough it may clip the beginning of the song (I think new players do not have this problem).
HTML code is On
Offset frames count for 59:58:00 RuffinMedia Post - Surround - Video 2 07-12-2012 08:46 PM
negative feet.frames offset? is it even possible? sndgeek Post - Surround - Video 7 06-20-2004 11:27 PM
dropped frames with white flash frames Frank Kruse Post - Surround - Video 6 05-08-2003 10:57 AM
Echofire latency / Offset frames (ms) ?? tomas_weber Post - Surround - Video 1 01-02-2003 03:04 PM
Nudging in frames, 1/4 frames and sub frames in PT 5.1.1 LE psax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-27-2001 10:43 PM
