Old 06-17-2023, 08:32 AM
EarHole EarHole is offline
Default I hoped 2023 would have fixed the bounce Mov Crash :-(
I'm on a M1 Mini Studio HD Native and the " feature" that crashes PT after each bounce to Mov has been a real drag. Last week I worked on 26 versions of a spot. So Bounce, deactivate Video Engine, Reactivate Video engine was getting boring and time consuming. I updated to 2023.6 hoping it would have solved things but no.
Old 06-17-2023, 01:43 PM
diamondschwin diamondschwin is offline
Default Re: I hoped 2023 would have fixed the bounce Mov Crash :-(
I have never been able to reproduce this issue, and I bounce out review Quicktimes dozens of times a week. I am on the latest PT with an M1 Ultra Mac Studio
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
Old 06-17-2023, 03:12 PM
BScout BScout is offline
You need to specify what codec you are using. "Mov" is just a container -- it can hold one of 10s of video streams. The problem is possibly with your codec and no one can tell because everyone else is using other codecs.
I have had zero crashes (as long as you don't extend past video for your selection or have blank frames internally due to editing the video; the last one only Ultimate users can do)
Old 06-17-2023, 04:46 PM
gives's Avatar
gives gives is offline
Well, I was a tester on the fix a couple of years ago for Avid and yesterday it started to happen to me again also on some full cuts of a film And a .wav. The movie bounced, but then the beach ball happened. Had to force quit and still the movie window was open and so I had to restart to get rid of it totally.
Then I did a bounce of audio only of the same film which was only 2.5 min long for a TV thing. that caused crash also. I'm digging into it for Avid tomorrow.
I have a ticket into them and they seem to think it was fixed and know that I worked on the fix with them with crash reports and testing. So, we will see, since it had not been happening in 2023.3 that I remember and especially not with just and audio bounce. the Codecs I use are all qualified rasters. ProRes422 etc.
I will post more when I get done. Will check Natively on this show and Rosetta 2, as it was in Rosetta 2 that it happened. Running a Mac Studio Ultra etc. see my profile for my info.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 06-17-2023, 06:47 PM
Are you doing same-as-source or are you rendering?
Old 06-17-2023, 08:26 PM
gives's Avatar
Good point-:)
I have had it happen on both though..
G
Old 06-18-2023, 03:06 AM
Ok, I primarily work with the dreaded MP4. It's what I get and I'm usualy getting prep minutes before session start and often updated picture during the session.
PT doesn't offer "Same as Source" and is greyed out for me.
Also, I usually Bounce to PCM. It sounds better and I use Simian which automatically converts files on upload and bouncing to AAC has effected the sound quality for me.
Old 06-19-2023, 05:36 AM
minister's Avatar
minister minister is offline
I bounce out the audio, then use Shutter Encoder. Load in the audio and the delivered MP4, select "Replace Audio". One extra step, but way faster than BTQT in PT.
I use Shutter Encoder to make MXF and import that into PT for working. Most efficient video format. To export a short clip, less than the full length of the video, then I will BTQT, then drop the exported video into Shutter Encoder and convert to H264. Ship that to client.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 06-23-2023, 08:15 AM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
I know the feeling..we often get mp4's and they're nothing but trouble, but I use https://www.ffworks.net to transcode to DNXHD, super fast !
Old 06-23-2023, 08:29 AM
gives's Avatar
Yes Very easy to do as Minister suggests. I like ffworks, which is super fast for me also, but either flavor is good. Some advantages to both.
I am not sure why the editor can't just send you a proper .mov format with the mix prep you receive. Seems odd to me. I always have a set standard setup well in advance as to what works for me and communicate that to producers. You can again aways transcode the QT after you do a "same as source" version. Not understanding why yours is greyed out for transcoding or is it a case of not being a certain ver of ProTools? I have to have everything to run my business here to expidite the workflow, which is key for us here.
G
HTML code is On
structure & 2023.6 - crash Fritz macOS 8 09-12-2023 09:31 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
BFD2 Win 7 64bit ProTools 8.0.5 crash FIXED! ozchapman The Drum Room 2 12-18-2012 12:29 AM
something i hoped never to see again ivanmil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-08-2007 11:08 PM
CoreAudio Crash on waking - will it ever be fixed? penx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2005 05:13 PM
