Free Recall Notes Plugin!!!!!
http://www.smassey.com/plugin.html
It's at the bottom. I never realized it was there. Steve Massey rules!!!!!
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
Re: Free Recall Notes Plugin!!!!!
He is THE MAN!!!
Massey for president! Thanks again Steve. Now we just need a great TDM Spectrum Analyser!!!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Aaah - awesome! Thanks, Steve.
Thanks, Kenny...
And the talkback i was actually going to request for this plugin and he's done it!!
Now we just need to share Recall presets.
I just made the Daking EQ and the Distressor.
Rock-on MR M
Auto-muting of TB Track during Playback 1 - Name a (mono) bus “*PB Key” “PB” being PlayBack. I use an asterisk to distinguish—and identify at a glance—software paths from hardware ones. 2 - Create a “PB KEY” track (mono) Put any continuos signal on this track—a low-mid frequency test tone will do nicely. To be frugal with disc space, print a few seconds of the test tone oscillator and repeat the region to cover the entire length of the session. 3 - Route the output of the “PB KEY” track to the “*PB Key” bus. Use the track’s output, not a send. It keeps this key signal out of your monitoring and printing paths, and is more efficient DSP-wise. 4a - Insert Compressor With Key (sidechain) Input on your “TB Mic” track Any compressor will do and its sound quality really doesn’t matter at all. What does matter is the the chosen processor be equipped with a “sidechain (Key) input. 4b - Select “*PB Key” bus as the (sidechain) Input on Compressor In addition to selecting a “Key Source” some plugins require that the key/sidechain function be turned on, or switched from “Input,” or “internal,” etc. Know thy tools. 4c - Adjust Compressor Parameters This is one of those rare occasions where the sledgehammer approach is preferred. The idea is for the compressor to clamp down as hard, fast and deeply as possible whenever the “PB KEY” signal appears at the sidechain input (which is only true when the transport is running). Like this: Compression ratio: Maximum Threshold: Adjust to be approximately 6dBs below the level of your steady key signal. Range (where applicable): Maximum amount of gain reduction allowed by plugin. Attack: Fastest setting possible Release: Slow this down a bit (adjust to individual situations), just to create a smooth “fade in” of the TB mic(s), whenever the transport has stopped. This is especially welcomed by those in a session who are wearing headphones. NOTE: Some compressors don’t offer enough gain reduction to completely mute a signal. No problem. Once all the steps listed above are completed, it becomes a simple matter of duplicating the compressor insert and its parameters until the required gain reduction is achieved. Option-dragging a plug-in is the fastest way to do this. Auto-muting of Reverb Returns At Playback Stop Repeat steps 1–3, as above. 4a - Insert Gate/Expander With Key/Sidechain Input on your “REV Return” AUX track(s) 4b - Select “*PB Key” bus as the key/sidechain Input on Gate/Exp 4c - Adjust Gate/Exp Parameters The comments I added to steps 4a, 4b, and 4c in the first example, are valid here also, albeit adapted. NOTE: Be sure to eliminate (or make inactive) these gates/expanders prior to mixing. Even though your reverb signals will make it through as intended, their presence at this point is undesireable because… a) you’re bound to unnecessarily color your delicate reverb signals, and… b) they’re a waste of DSP. . The possibilities are nearly endless. IHTH. .
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Great! Recall Notes is a must have. . . I can never find paper.
Question - I created a Popup list using the format popup: item1; item2; item3; and it works, but once created I can not see how to modify the popup list in the case one makes a mistake creating the Recall sheet template. Anyone know? |
Lets just ask Steven Massey to make a plugin
Snapshot/plugin recall issue | Realdon | VENUE Live Sound Systems | 5 | 05-01-2012 01:27 PM |
Structure FREE shortens long notes | aus scott | Virtual Instruments | 6 | 07-09-2009 07:07 PM |
Structure free - Notes not sustaining anymore | Murt | Virtual Instruments | 4 | 05-12-2009 03:30 AM |
Power Harness Recall of the Recall ! | ChuckLogan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-21-2004 09:06 AM |
PlugIn-recall of diff. setups-while runnig-Altiver | Ploch Klaus | Post - Surround - Video | 3 | 12-29-2003 04:33 AM |
