12.8.1 - Panning Bug on my System
http://protools.ideascale.com/a/idea-v2/280449
Sierra, PT 12.8.1 HDX Panning automation erroneously GLIDES depending on entry method. Steps to re-create: •In a new session, create a mono track. Instanciate Signal generator; pink noise suggested. • Using only mouse and the normal pointer tool, draw automation that hard cuts from left to right (say every whole note on the grid). This will play back the automation properly as expected. • Delete the automation and re-create, but this time, use the trimmer tool to create the automation (that hard pans every whole note). On my system, this will play back incorrectly. The automation will not hard cut as drawn, but will glide to the point over the course of the bar. Totally odd! Even stranger, if I use the regular pointer tool to manually move each dot and then put them back again, the automation will now playback properly. My deduction is that there is some type of bug when the automation is created using the trimmer. I sure would appreciate it if anyone else could verify this bug! Thanks! Last edited by DigiTechSupt; 09-16-2017 at 12:23 PM. Reason: Added IS link. |
Re: 12.8.1 - Panning Bug on my System
I've seen something similar on vanilla, when I highlight a section and use the trim tool to change the volume or any other automation parameter for a few bars it will gradually return to the original position instead of following the lead. If I readjust the points manually with the pointer it works as intended.
I'm yet to check if this is happening on 12.8.1 because I have been recording all my automation in real time with latch since I first came across this a few versions back.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Can you confirm if this started for you in 12.8.1? Haven't been able to repro here (though running Pro Tools HD 12.8.1 on Mac Mini or Eleven Rack if that's a factor). Will start a support case to get example sessions from you.
• linkedin •
Havent been able to reproduce it ... tried with pencil, trimmer and multitool...
www.innenhofstudios.at |
Forrester |
• linkedin •
Glad that is logged. Happening here also.
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Just for adding to the post , cannot reproduce here neither ! :-/
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
FYI I have the same issue in PT HD 12.8.0. My workaround is to add breakpoints just barely inside the breakpoints created with the Trimmer tool.
Michael James michaeljamesproducer.com www.IndieProMix.com System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives |
Panning law for TV | antonis | Post - Surround - Video | 2 | 11-16-2014 06:23 AM |
Panning not available? | Jakay | Pro Tools 11 | 11 | 11-21-2013 04:49 PM |
Panning law bug for 10.01? | dtmprod | Pro Tools 10 | 3 | 02-04-2012 07:26 PM |
Panning! | barismanco123 | Tips & Tricks | 7 | 12-07-2009 08:07 AM |
panning | genoveva | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-29-2006 05:55 AM |
