"You cannot run Pro Tools as 'root'. Please login as a user with Admin priviledges...
Hello colleagues . I am running Pro Tools 7.4cs10 on a mac g5 PPC dual 2 ghz. When initializing Pro Tools it thinks I'm logged in as ROOT user and not as an ADMINISTRATOR (I'm logged in as ADMIN) in OS X 10.5 therefore it won't open. Anyone know about this? This happened randomly, nothing new has changed or upgraded, etc...
Thanks! |
Re: "You cannot run Pro Tools as 'root'. Please login as a user with Admin priviledge
10.5 means you should be running 7.4.2.
I believe 7.4cs10 is for OS 10.4
... but does it help the chorus? |
I'm downloading version 7.4.2 Hopefully that'll help THe "funny" thing is that this happened out of nowhere, without updating the OS . I was having problems with the mac booting past the apple screen, it would freeze. Got that solved and then this happened. Thanks for your post |
Did you try deactivating the root user in your Directory Utility? I may be mixed up in my Mac OS versions, but I think it's in the Edit menu of the Directory Utility found in the Utilities folder inside Applications. Reactivating it when you need it takes a few seconds, so I always deactivate it after use (or just use sudo in Terminal).
If your root user is deactivated and you still get that message, you're really in weird territory. It may be worth opening Terminal and entering the "sudo password root" command, where "password" is your root user password, which should switch the root user's state. |
Have you repaired permissions lately?
Does enabling a root user mess with PT? | CalebB | macOS | 1 | 10-24-2012 08:01 PM |
Avid admin,Where are you???PT LE 8 registration and avid login not jiving??? | jacobsapple | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-03-2011 10:40 AM |
What Happened to the Certified User Login?? | MUSIII | General Discussion | 0 | 06-16-2006 01:44 PM |
terms.... "root folder"... etc | gitarzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-12-2003 11:23 AM |
User Login Enabled - Performance Implications | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-20-2000 04:09 PM |
