Old 05-22-2021, 08:30 AM
niconico niconico is offline
Default Re: Recorded track playing back rushed .... ???
Incase anyone is running into this issue ive been having the same problem and found a solution. The CLICK plugin is midi based so if you have a 'Midi Offset' set under midi preferences (PRO TOOLS > PREFERENCES > MIDI) it will change the timing of the click. This is probably why clearing the pro tools preferences in the system library solved the issue above, but the cause may have been the offset.
Im not sure if the default Midi Offset is 0 or i changed it along the way sometime.
hope this helps. Ive been thinking i have horrible (but consistent) time as im always ahead of the beat. now i know!!
Recorded audio playing back too early jonwade92 macOS 3 04-15-2013 01:01 PM
Recorded are sounds playing back early?? thierryhenry macOS 2 03-12-2013 11:26 AM
Session playing back at twice the recorded speed. horsearound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-21-2011 04:35 AM
not playing back in the tunning recorded guitarhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-19-2006 04:58 PM
Recorded Midi in session not playing back? Kdowg Pro Tools M-Powered (Mac) 1 11-28-2005 08:48 PM
