  #31
Old 10-06-2022, 02:41 PM
Ben Jenssen's Avatar
Default Re: Pro Tools Intro (free)
Hmmm…
So why doesn't Avid just let everyone with a paid PT license just have a Intro license put on their account? That would have been easy and tidy, but I guess easy and tidy is not what they're going for.
  #32
Old 10-13-2022, 05:06 PM
gblentz gblentz is offline
Originally Posted by gblentz View Post
I'd like to have Pro Tools Intro on a couple remote machines away from my main Pro Tools rigs, mostly just for noodling and "jotting down" sudden inspiration.
Would these instances interfere at all with my perpetual licenses (one of which is Pro Tools 10)? Would it be safer to create a separate account just for Intro?
Bump
  #33
Old 10-13-2022, 05:16 PM
[edited to get things right, sorry been busy/distracted]
You shouldn't need to, nothing here should be an account/licensing issue. Intro uses machine based licensing, so just license the machine. You need to find a version of Windows/way of installing that support Pro Tools 10 and Intro 2022.9 that lets you do a dual-install, I have no idea if that is still doable, but it's just the same question as installing Pro Tools 10 and Pro Tools 2022.9 on the same computer... not actually sure if that's still doable or not, but the challenge there is nothing to do with licensing. Worse case you will need to set up systems to dual-boot.
Where are also likely to run into issues is if there are additional .aaxplugins installed on the system. Just having the intro machine license present means that Intro will barf on all those plugins not being licensed. And then if they all get moved to the Unused folder that may not be what other users want. This is a problem that was obvious with First and I hoped Avid would have thought through, maybe with a separate preferences list for plugins only active in Intro. It would not be hard to manage moving plugins out or back in with a shell script before running either version, but also might be another reason to just go to dual boot.
  #34
Old 10-14-2022, 09:35 AM
Thank you so much Darryl. I would only want to put PT Intro on what you might call a "peripheral" system... one which I could still bang out some ideas on when I don't have access to my main rig. That machine is already set up as a Windows 7-PT10 / Windows 11-PT2022 Perpetual dual boot system, and I wouldn't be touching either of those installs at all.
So my main concern then would only be with any licensing implications... specifically not wanting to crap on my existing PT10, or PT2022 Perpetual licenses by adding PT Intro (which I'm still fuzzy on as to whether is considered perpetual or subscription) to my iLok/Pace account.
As for AAX plugins—noted. Many of the ones I have are not "iLok'ed" and allow activation on a second machine, so long as only one is in use at any given time. I'll be out of luck with the rest, but then again I wouldn't be planning on doing full mixes requiring them on PT-Intro anyways.
  #35
Old 10-14-2022, 10:55 AM
There should not be a licensing issue, I have PT Intro licensed to my Mac here, and separate iLok license for PT Studio etc.. And that Intro uses a machine license makes this easy to leave on the computer if the iLok(s) with main licenses are elsewhere being used.
  #36
Old 12-21-2022, 10:11 AM
Ru_C Ru_C is offline
Hi all, I'm sure the answer is staring me in the face, but I can't seem to see it.
Question. Can I install Pro Tools Intro on the same machine as Ultimate 22.10?
It would be handy to be able to demo it to musicians I work with, who up until now have used GarageBand, Ableton Live-Lite etc for home demos, before they book into my studio.
Cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
  #37
Old 12-21-2022, 10:33 AM
JFreak's Avatar
JFreak JFreak is online now
Intro and Ultimate are the same install, it is just a matter of what license you hold on your iLok.
Janne
  #38
Old 12-21-2022, 10:57 AM
I.e, when you launch PT, if it sees only the machine license which is for Intro, only Intro features will be available. If you have an iLok plugged in with an Artist, Studio, or Ultimate, it will have the features for that license active. There is only one PT installer.
Tascam DP-01FX (and my Intro) Supertramp Getting Started 4 03-05-2019 06:11 PM
fast way to lengthen intro lucidlife Pro Tools 11 3 10-09-2015 08:53 PM
Not A Good PT8 Intro... papasight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-09-2010 10:27 AM
How to add an intro? Sonic Blue Meanie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2010 07:40 AM
Intro and some trouble PT_n00b Pro Tools M-Powered (Win) 5 01-30-2009 05:49 PM
