PTF bounces
I'm having very frequent crashes when I do bounces with PTF. The error message tells me to increase buffer size but I'm at max already. It seems to happen only on longer tracks (2-3 minutes are usually OK, more is almost always a problem). My comptuter DOES use a VIA chipset. It's a P-III-800 made up of first class components. Everything else works fine, so it's quite frustrating not to be able to put my work to CD.
Can anyone help? |
Re: PTF bounces
Disable Virtual Mem, Defarg HD, disable any hardware not being used during bounce: Modems, NIC, USB Devices and I/F, anything...
Close any anti-virus or other program that use CPU sometimes, check the DMA Enabled & uncheck the CD Autoplay/Insert Notification. For further help search the entire DUC for H/W Buffer Size.
Just wanna do music, RA. |
Re: PTF bounces
I found that bounce to disk placed the most demands on the system so it is vital that everything else is switched off.
I even need to close the edit window!Presumeably closing the mix window would also help? Curiously though, it only works if I set the buffer to zero??? Also, if you are converting ( I have a sblive! so have to convert from 48 to 44.1), then make sure you set up a master track and use dither. Hope some of this works, Sweave [This message has been edited by sweave (edited April 30, 2001).] |
Re: PTF bounces
Re: PTF bounces
11.0.2 TC/E - odd bounces | talkingbooks | Pro Tools 11 | 14 | 05-07-2014 09:05 AM |
ADC and bounces | EricWillhelm | Pro Tools 10 | 3 | 12-20-2013 09:44 AM |
Schedule Bounces | Andrew Bob | Pro Tools TDM Systems (Mac) | 11 | 06-24-2009 04:58 AM |
7.3 on 10.4.9 bounces once, then nothing | DjA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-18-2007 07:53 AM |
5.1 bounces | PPRECS | Pro Tools TDM Systems (Mac) | 1 | 04-07-2007 01:14 AM |
