Old 09-30-2023, 02:31 PM
TrentWilliams TrentWilliams is offline
Default Disabling Spotlight Indexing
Hey all,
Just working back through the optimisation guide and noticed spotlight had been re-enabled, on trying to disable it permanently again I'm getting a kickback in terminal.
sudo launchctl unload -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
Unload failed: 5: Input/output error
Try running `launchctl bootout` as root for richer errors.
I'm able to disable it until reboot using - "sudo mdutil -a -I off"
Running the same command with SIP disabled in recovery mode yields "Command not found".
Is anyone able to give some insight before I reach out to support?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 09-30-2023, 02:49 PM
Default Re: Disabling Spotlight Indexing
What macOS version are you running? Is 11.6 in your signature correct? What have you been doing to it? Major InSitu updates?
As the error message said what does bootout show? e.g.
[edit: Bzzt wrong bootout example, see comment below it does not help anyhow]
(Works fine for me on an Intel MBP running a fresh install of Sonoma).
Spotlight is a mess, but if you want to index say some of your drives you can mark the other drives private... but just look out if you do for Spotlight indexing still getting upset/spinning/chewing CPU (or I/O on HDD).
Old 09-30-2023, 02:57 PM
$ sudo launchctl bootout load -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
Thanks for the reply,
Sorry, signature is out of date - running 13.6
Running bootout gives back
"Usage: launchctl bootout <domain-target> [service-path1, service-path2, ...] | <service-target>"
Old 09-30-2023, 03:04 PM
Doh Ya already unloaded it.
Try putting it back..
$ sudo launchctl load -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
then taking it away...
$ sudo launchctl unload -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
Old 09-30-2023, 03:16 PM
Ah, thanks for your help with this.
Is there a way I can see current enabled/disabled status of spotlight in terminal?
Running: sudo launchctl load -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist
Yields: Load failed: 5: Input/output error
Try running `launchctl bootstrap` as root for richer errors.
Old 09-30-2023, 03:21 PM
Oops and my bad for messing up the bootout example. Which would actually not have given any more clues anyhow, e.g. on my system...
Code:
$ sudo launchctl list | grep mds
-	0	com.apple.metadata.mds.scan
-	0	com.apple.metadata.mds.index
-	0	com.apple.msrpc.mdssvc
-	0	com.apple.metadata.mds.spindump
4584	0	com.apple.metadata.mds.scan
4583	0	com.apple.metadata.mds.index
4581	0	com.apple.metadata.mds
$ sudo launchctl bootout system/com.apple.metadata.mds
Boot-out failed: 3: No such process
Old 09-30-2023, 03:31 PM
massivekerry's Avatar
massivekerry massivekerry is offline
I’ve been using AppTamer to throttle Spotlight Indexing and force it to the Efficiency cores.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 09-30-2023, 03:37 PM
its2loud its2loud is offline
Spotlight should be enabled. Which optimizations are you looking at.
Spotlight needs to be enabled for Workspace to function.
Unless you’re doing long record passes.
https://avid.secure.force.com/pkb/ar...ng/Optimize-12
Old 09-30-2023, 03:51 PM
In the optimisation guide for Ventura:
Disable Spotlight Indexing
Running Spotlight on macOS Ventura can impact Pro Tools playback performance.
To turn off Spotlight permanently:
In the Terminal, run "sudo launchctl unload -w /System/Library/LaunchDaemons/com.apple.metadata.mds.plist"
To turn off Spotlight until reboot:
In the terminal, run ”sudo mdutil -a -i off”. Consider running this command when you know you will be using Pro Tools on startup.
Exclude any folder or drives from Spotlight indexing and parsing that may be causing Spotlight to parse files during audio playback. This is particularly relevant when parsing large image or video files.
Old 09-30-2023, 03:53 PM
Code:
Thanks again for your help with this,
Running:
Code:
Yields:
Code:
111	0	com.apple.metadata.mds
This appears as though it's unloaded, I'm unsure about:
Code:
Disable Spotlight Indexing? jack s. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 10-15-2010 12:59 PM
disabling Spotlight question Dopamine Pro Tools TDM Systems (Mac) 5 11-04-2008 03:17 AM
The Deal with Spotlight Indexing? Dabeed Pro Tools M-Powered (Mac) 2 01-05-2008 07:18 AM
Spotlight Indexing.....HELP! KMAN385 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2007 09:37 AM
Disabling Hard Drive Indexing? francona Pro Tools TDM Systems (Mac) 4 12-06-2001 09:47 AM
