overheads & ping ride
Hi guys,
I did a drum recording where the drumer played a ping ride at 1 o'clock. I also have a close mic of that ping. In the mix I would like to have it more "obviously" on the right side (2 or 3 o'clock) but I'm not able to get a "satisfying" result by paning the close mic more right. There's too much signal coming from the OH and the SN mic pulling it back center. Any trick I've overlooked? I know I could simply leave it where it is but I want that part of the song a bit larger. Thanks
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32 |
Re: overheads & ping ride
What does the overall drumkit image looks like in the overhead?
Is the image well balanced? Is it wide enough? Does it have a solid center? Depending on your analysis you could consider manipulating the imaging with an m-s tool.
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
yes, the overall image is ok. KI and SN int the mid. Even the ping ride is correct but like in the real kit at 1 o'clock.
If the image is not overly wide you could maybe try widening it/droping the center a bit and compensating with the close sd/bd mics... hard to tell from over here.
pt 9 smooth ride | Filmusic | Pro Tools 9 | 4 | 11-24-2010 05:47 PM |
Can't get the crash-ride in BFD lite to sound like at true ride-is this deliberate? | studiostrat | Virtual Instruments | 3 | 09-11-2008 02:55 PM |
How to Over-ride 002R Pre's? | Rick Akoni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2006 10:16 PM |
Drum overheads sound without overheads | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-12-2003 06:57 AM |
Which bus should I ride? | ripple FX | Storage Subsystems | 5 | 09-26-1999 02:37 PM |
