  #71
Old 10-03-2022, 02:55 PM
scaramangaindustries scaramangaindustries is offline
Default Re: EuControl & Mac Studio
EddieJones nailed it. Thanks so much!
Mac Studio Ultra Mac13,2 Monterey
Model Name: Mac Studio
Model Identifier: Mac13,2
Chip: Apple M1 Ultra
Total Number of Cores: 20 (16 performance and 4 efficiency)
Memory: 64 GB
Activation Lock Status: Enabled
Carbon
Antelope Orion Studio 2017
2x Samsung PSSD T7 Shield Media
My name is Matthew Saccuccimorano
  #72
Old 01-29-2023, 08:29 PM
psycho_monkey psycho_monkey is offline
Originally Posted by EddieJones View Post
As Howard says there seems to be a problem with the migration. If you can do what Howard says that would help us determine the issue. A workaround we think fixes the issue is to change your computer name and reboot. It can be just one character. This is done in System Preferences->Sharing.
Don’t use the Edit button, just change it right in the Computer Name field then tab out of it.
Thanks for that - that fixed things for me too.
Which is weird 'cos I did a fresh install on my Mac Studio to avoid issues like this!
Ah well - we appear to be good now :)
  #73
Old 02-21-2023, 01:40 AM
georgesenior georgesenior is offline
Hi, found this thread and was hoping it would solve my issue as it seems exactly the same.. M1 Ultra Studio (Running Monterey 12.6.3) which detects the S1's through Eucon (2022.9) but won't communicate with Pro Tools (2022.10). I have tried the name change, ticking rosetta in both Eucontrol and MC_Client and also removing both Eucontrol and MC_Client from Security/Accessibility reboot and then re-adding. I've also done fresh reinstalls and tried a combination of compatible Eucon/PT combinations. I've contacted support but still waiting on a response and it's quite a pressing issue. Any help would be much appreciated!
  #74
Old 02-22-2023, 08:57 AM
HowardSw's Avatar
HowardSw HowardSw is offline
Hi George:
Could you post a screen shot of the Discover app as described in these two posts?
https://duc.avid.com/showpost.php?p=...3&postcount=22
and
https://duc.avid.com/showpost.php?p=...8&postcount=24
Thank you
  #75
Old 02-23-2023, 09:21 AM
EddieJones's Avatar
Can you also check the Workstation tab in EuControl and see if its listed in the right hand column.
  #76
Old 02-25-2023, 08:06 PM
Cryos's Avatar
Cryos Cryos is offline
I have a Mac Studio M1 Max 10 core 32 core GPU. IPad app would shut down the control app all on its own till I read a post to run Eucontrol on the Mac in Rosetta . Has stopped doing that since I did that .
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
  #77
Old 02-28-2023, 04:49 PM
APsound APsound is offline
Also checking in here. Mac Studio Ultra, 12.5.1, PT Ultimate 22.10, Eucontrol 22.9, S1+Dock+iPad. After opening in Rosetta, I haven't had any Control App crashes or loss of connection with either the iPad or Dock/S1. iPad is connected directly via ethernet adapter.
Mac Studio Ultra, 12.5.1, PT Ultimate 22.10, UAD Apollo Quad (grey), S1 + Dock EuControl 2022.9, EUCON 4.8.6.44
  #78
Old 02-28-2023, 05:52 PM
James Steele's Avatar
James Steele James Steele is offline
That's interesting. I'm not using the control app, just MC Control and MC Mix so I'm letting Eucon run native and no problems with that setup.
M1 Max Mac Studio, 64GB/2TB, macOS 14.5 Public Beta, DP 11.31, Pro Tools 2024.3.1, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Avid S3, Console 1
  #79
Old 03-01-2023, 09:36 AM
EddieJones's Avatar
We have found the issue that is fixed running under Rosetta and it will be in 22.12.1 (so you can run natively again)
  #80
Old 03-03-2023, 12:35 AM
Cryos's Avatar
This may sound like a stupid response but I had a 2nd mac on my network via wifi with eucintol installed on it and whenever that network mac was booted up and Eucontrol was active it would take control of all my controllers. I was scratching my head wondering why my main Mac wasn't allowing me to access the controllers. Then I realized the network mac has seized control of all of them. I quit Eucontrol on the network mac and all was able to have access to all my controllers again.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
EUControl not working as Makie or HUI with Studio One? Captain Al Artist Series 20 04-24-2024 09:33 AM
MTRX-Studio activation card # won't work. How do I get EuControl? DeadlyMixProd Avid S1, S3, Dock and Control App 2 12-29-2021 05:29 PM
Can ProTools Vocal Studio work in Pinnacle Studio 14.01.7256 Sharon Lee Taylor Pro Tools SE and Essential (Win) 2 08-28-2010 08:39 PM
Logic Studio taking files to pro tools studio. smoochdaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2009 10:55 AM
Studio interrior! Let's show them home/appartement /garage studio's :) Gr0und_Zer0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 200 05-18-2003 05:40 AM
