Need good advice for an older setup
I acquired a bunch of older stuff with HD3 cards in a G5(not booting). Given that early Mac Pro's are a bargain, I'd like to run PT10HD, so which Mac Pro and OS will work with:
Early HD3 cards(PCI) PT 10HD(which I have) I have tried to understand the compatibility grid, but there is some confusion there(especially for a Windows guy) and it looks like Leopard is the right OS. It also appears that things can change if I use an expansion chassis(the package also came with a brand new Digidesign-branded chassis, which I could move the cards into).
Re: Need good advice for an older setup
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
Hmm, they are in a G5 at the moment so I do assume they are PCIx. I was led to believe the first 1,1 and 2,1 had PCI slots(of course, by someone trying to sell a 2,1 Mac Pro). The chassis is PCI with a PCI card, so that doesn't help much. I suppose I could scrounge a working G5, but will that run PT10?
Don't assume, check. If it is the very latest generation G5 PowerMac, it has PCI-express. Other G5's have PCI-X.
If it is PCI-X the OSX version you want to be using would be latest Tiger, and PT version that works most stable would be 7.2 which was the last PPC-only version. Whatever you do, skip 7.3 as it was first Universal Binary release and very buggy. Leopard was a stopgap solution during PPC-Intel transition. Sure, it introduced new features such as Time Machine, but it was not really good for PPC and not really good for Intel. But if you go there, you want to be using PT 7.4.2 not PT8.0, and there is zero chance of getting heat to work on PPC as it was released in PT 8.1.1 which requires Intel.
Thanks for that, I did manage to find specs on the early Mac Pro's and off the wall is correct that all Mac Pro's have PCIe slots. The cards I have are in long black slots and have long contact strips, so I guess that makes them PCIx. I see now why the chassis was not being used as it has shorter white slots(probably PCIe x16?). Not short like the blades on the PCIe cards I have seen, but the cards I have will not fit the chassis(and the chassis card that goes in the tower will not fit the G5 slots either). I guess this leaves me finding another G5 or a suitable(and old) Windows 7 PC that can take the cards and run PT 10HD. Anyone remember a good mobo for that vintage of PC?
Also, do my PCIx cards fit in standard PCI slots(thinking about a PC)?
PC's are a bit tricky about cards. HD cards are full length, so the slots need to be physically capable of taking full length card. Maybe you would be more happy with old Magma PCIX-to-PCIe chassis/card, if you like Mac Pro better? Or simply just work with you have and install what I told you.
Which license verions you have by the way? Or have you not yet bought one? If you do not have old license, then my best bet would be trying to find 7.2 license second hand from fleebay and just install Tiger to your G5.
I mean... if you don't have and cannot find 7.2 or 7.4.2 or 8.0 license you can forget about that G5 PowerMac
I see, I thought the G5 could go to Leopard and it looked like that combo would work with PT10. I suppose somebody must have an older HD license if I am stuck with a G5. Trying to keep my cash outlay as small as possible on this. I read some posts about a Jetway motherboard that had 4 PCI slots and those can be found on eBay with a quad CPU for a bargain(less than a used G5) and I have case/graphics and PSU in a closet. I'm just a bit out of my wheelhouse on this older stuff
If you decide to go there, let me know because if interested I could probably help out with a 7.2 or 7.4 HD license for a fair price.
Len B. |
Is a new Mac good for Pro Tools and older plug-ins? | Infiltrator | macOS | 0 | 12-17-2011 08:35 PM |
Advice needed to upgrade older setup. | needtopractice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-21-2011 06:05 PM |
Proper SCSI setup/advice? (for older Mac/AMIII) | edgarbc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-08-2004 11:38 AM |
Who makes GOOD KVM switcher for older macs? | MX | Pro Tools TDM Systems (Mac) | 1 | 07-04-2003 12:45 AM |
Is an older 882 I/O usable in a new setup? | Sanj1967 | General Discussion | 1 | 11-29-2000 05:39 AM |
