Old 01-20-2019, 04:37 PM
banjo71 banjo71 is offline
Default Anyone use AutoTune EFX-3?
I'm having 'close and save' issues with AutoTune EFX-3. If there is at least one active AutoTune EFX-3 plugin on any insert, you can try saving the session but it won't close until after you hit 'close' and it brings up the screen 'save before closing?' In other words, you know how the "Save" text should go from dark black to grey after you try saving? It stays dark black, and so I'm hoping that each time you try saving through the Save text it actually saves the session in your external drive. I know it does after you hit close and then click on Save before Closing.
And if you deactivate the plugin, or remove it from the inserts, the session saves and closes normally. So I guess I've been figuring out the parameters of the EFX-3 for a vocal, copying the settings, removing the plugin, and using AudioSuite, pasting the settings into the EFX-3, and rendering the process. This eliminates any need to keep an active EFX-3 plugin on any track chain.
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Warm Audio WA12 MKII Preamp
Glyph 1TB GPT50 external drive - Firewire
LaCie 1TB external drive - USB
JBL LSR305 monitors
AT 2020 & 2021
Equation F.20 condenser mic
Old 01-21-2019, 12:56 PM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Default Re: Anyone use AutoTune EFX-3?
I use AutoTune EFX-3 on OSX 10.10.5 / PT 12.8.1 without any issues.
I take it you've already tried thrashing prefs and reinstalling the plugin?
T
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Old 01-21-2019, 02:14 PM
Yeah I’ve done those things. I also tried uninstalling and reinstalling.
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
Old 01-22-2019, 04:39 AM
Muddy-T's Avatar
It seems not many here share your experience. Have you tried opening a support ticket at the Antares help desk?
http://support.antarestech.com/support/home
Or -last resort- ask around on GS...
T
Old 01-22-2019, 07:07 AM
I did create a ticket for Antares twice - one was a quick response they would look at it for a future update. The next ticket I created I mentioned it along with a different click/pop issue creating pops on the rendered waveform using EFX3 I was having. They helped me with my click/pop issue (run the buffer size up when you’re processing plugins) but didn’t say anything about the save/close issue. I’m running PT 12.6 and should be ok.
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
Old 01-22-2019, 08:59 AM
AlexLakis AlexLakis is offline
EFX-3 on the latest Mojave, Pro Tools 12.6, 2018 Mac Mini, working fine here.
HTML code is On
autotune vs melodyne (looking for keyboard input feature in autotune) heidib123 Pro Tools 2018 5 01-09-2019 11:14 PM
autotune vs melodyne,.. (looking for keyboard input feature in autotune,..pls help..) heidib123 Getting Started 4 07-06-2017 12:31 PM
Autotune 4 and PT 8 Tom Pfaeffle Pro Tools TDM Systems (Mac) 20 11-23-2009 11:02 AM
AutoTune 6 with PT8 Eric Seaberg Pro Tools TDM Systems (Win) 4 05-23-2009 12:00 PM
new to autotune...Help dheding 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-16-2003 11:11 AM
