Old 11-19-2008, 02:44 AM
ejwells's Avatar
ejwells ejwells is offline
Default New Quad Up And Running
Just a report from your long lost pal.
My new quad absolutely rocks.
Q9550, 4 gigs 1066 RAM, dual DVI graphics card, 250 OS Drive, 4x500 audio drives, in a nice 4U rack case. I had it built by a small company out of Pennsylvania. I'm just not a builder. I probably paid $400.00 more than I would have paid to build it myself, but I paid less than half of what this would cost at Sweetwater.
I haven't done an official DVerb test, but large sessions that would need to be at 1024 during mixing (with L3's and other CPU hog mastering plugs) on the master faders, now run effortlessly at 128!
My only issue (and it's a small one) is a dual display issue.
With my old displays/graphics card I would drag the main PT screen across to fill the 2nd display, and that'd be that. Sessions/PT would always open in this mode.
I can't seem to do that with my new setup.
When I open PT, I can't drag the main screen on to the 2nd, and have to maximize it. One I get a sessions properly sized, they'll then reopen correctly. But, when I fire the system up and load PT, I still have to maximize the PT screen first, then all is well. Sessions I've worked on open properly. Sessions I've not opened on this new system still have to be sized, as these are new displays (my old displays were 18" standard ratio, these are 22" cinema ratio).
Any thoughts on this?
But, I'm telling you, if my only issue is having to maximize the PT screen when I first fire up for the day, I've got very little to bitch about.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 11-19-2008, 04:27 AM
sbag sbag is offline
Default Re: New Quad Up And Running
i just got a quad to from a small company in pa. TRS is this the same cats
you purchased from? my machine runs great.
good luck with new cpu
ej
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
Old 11-19-2008, 07:18 AM
trock trock is offline
Hey Guys
Thats really cool, i have an older quad q6600 and it smokes on cubase, i am trying to decide to jump to LE, can you confirm that LE works across all 4 cores well?
i can't seem to find this info for sure. my rep told me it only works on 2 cores since they want you to buy HD?
Old 11-19-2008, 08:12 AM
ejwells's Avatar
Yep. TRS. Nice guy, great service thus far.
Old 11-19-2008, 08:14 AM
VanDerGraf VanDerGraf is offline
LE works on all four of my cores. I have had the occasion when it was running slowly and I checked and it said it was using only 1 core, but a quick re-boot fixed that. It's rare. Overall I am very happy!
vandergraf.net
"All the truth in the world adds up to one big lie" :: Bob Dylan
Old 11-19-2008, 10:18 AM
DigiTechSupt's Avatar
Yes, it does.
Avid Audio Tech Support
Support FAQ
Old 11-19-2008, 04:52 PM
hey thanks very much!
I was told differently so hearing straight from you guys is fantastic
Old 11-19-2008, 10:19 PM
MDog MDog is offline
After maximising to both screens, try quitting Pro Tools using the button on the Task Bar. Just right click and select "close". PT should open correctly from then on. You only have to quit that way once. That's the known solution for that particular "bug". It works for me, anyway.
Good luck!
My best friend is a pitbull.
http://www.badrap.org
anyone running HD native on a Woodcrest Quad 2.66 1, 1 Mac Pro snacky Pro Tools HDX & HD Native Systems (Mac) 10 11-24-2011 12:34 PM
Running out of CPU power on Quad Core? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 12-23-2009 11:19 AM
Looking at getting Quad Core 3.0 GHz, running Leopard 10.5.1 Ruzzo Pro Tools M-Powered (Mac) 3 04-27-2008 08:15 PM
Anybody got a 001 running with current dual/quad setup? Keeron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-11-2007 01:02 PM
Running PT HD on intel Q6600 Quad with i975X chipset ... olek Pro Tools TDM Systems (Win) 11 10-06-2007 06:16 AM
