Running Out of CPU Power
I keep getting the "You are running out of CPU Power. . ." error message (-9128) and I'm not sure what to do.
I use the computer only for recording, and have just re-set everything. The hard drive has been newly reformatted and I haven't installed anything else on the computer, so there's nothing else that can be eating CPU power. I am running Pro-Tools M-Powered 7.0 with a Firewire 410 on Windows XP Professional Edition SP2. All I am using right now is one guitar track with amplitube 2, and Reason 4.0 Rewired with only Redrum and two synthesizers. I have a Pentium 4 1.9 ghz processor and 1.5 gigs of RAM. I trashed all my settings, followed all the instructions in the getting started guide and the general troubleshooting thread, and still no luck. Any advice? I'm not sure what other info to supply so I just gave the basics and please let me know what else you need to help me out if you can. Very much appreciated! |
Re: Running Out of CPU Power
Both of those plugins can be CPU intensive. They both have effects that will require CPU performance, and Reason is almost an entire DAW in itself.
Your 1.9ghz P4 is getting a little long in the tooth. The performance you describe doesn't sound too out of line for the power you have available. |
Wait... Amplitube 2 and Reason rewired with Redrum and 2 synths? On a P4?
You are probably pushing the P4 to it's limits with Amplitube alone. Quote:
One suggestion I always make (especially on older, underpowered systems) is to "print" the guitar tracks and disable the amp simulator.
with a P4, thats a tall order. And PT is prolly the most demanding of most DAW's in itself.
Try using something like Reaper, and it should show substantial advantage. Cheers! Sidhu
Hp Probook 4530s. i3 Sandy. 4gig RAM TI/VIA Firewire expresscards. |
Amplitube is a CPU assasin. Don't get me wrong, I love it, but it will beat the livin' heck out of any single core P4. Even on my old Athlon dual core, 3 or 4 Amplitubes and my system was screaming for mercy.
You might want to consider a system upgrade in the near future. It'll make your life a lot easier.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
So I'm going to get a new computer, but I don't have all that much money to spend. I'm going to use it solely for recording, mainly running pro tools, reason, and amplitube. This computer looks like it might do the trick, but I'm not as familiar with the requirements of these programs as I used to be. I'll be downgrading it to XP. . .does this look decent? Thanks again for all the help.
http://www.bestbuy.com/site/olspage....#productdetail |
snip
http://www.myspace.com/blaqmusicgroup |
http://www.portatech.com/25353/Produ..._Intel_CPU.htm
http://www.portatech.com/25352/Produ...th_AMD_CPU.htm
u need a better cpu like i have i have a quad core intel 6600 cpu and i have no problems running resons adapted or amplityude upgrade buddy
running out of cpu power??? | amoretam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 10-26-2010 11:58 AM |
Running out of CPU Power Tip Here | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-08-2008 08:43 PM |
Running out of CPU Power | npratt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-20-2004 04:04 PM |
running out of cpu power | Jumpman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-06-2004 06:07 AM |
Running out of CPU power w/ 2.6 ghz 1GB of RAM?!?! | 72reissue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-29-2004 04:56 PM |
