Old 06-05-2008, 05:22 AM
amj665 amj665 is offline
Default My Profire 2626 not work with teh pro tools
hi all
i have the Profire 2626 put i get problem !
when i run the pt i get this massege
"unable to locate M-Audio hardware Macke sure your hardware is connected and turned on"
the 2626 is turned on and connected
please let me run it and what i can do
i remain
Old 06-05-2008, 08:31 AM
DigiTechSupt's Avatar
Default Re: My Profire 2626 not work with teh pro tools
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well.
Avid Audio Tech Support
Support FAQ
Old 06-05-2008, 10:00 AM
Soylent Green Soylent Green is offline
If you are running MP 7.4 then you probably just need the cs5 update
http://www.digidesign.com/index.cfm?...4&itemid=32330
If this doesn't work. Check to make sure you have a supported Fire Wire chipset
It would show up in your Device Manager under IEEE as Texas Instruments OHCI compliant
If you have something other than that then that would most definitely cause you problems
Old 06-05-2008, 11:53 AM
MDog MDog is offline
I had the same problem until I switched firewire cables. The cable I was using worked fine on my old 1814, but the ProFire 2626 didn't like it at all. I also bought the Digi approved Siig firewire card which solved some other issues as well.
My best friend is a pitbull.
http://www.badrap.org
Old 06-05-2008, 12:55 PM
thank for all
i do all the thins that you tell me put still i can't run the PT 7.4
i still get hte same massege
please i neeeeeeeeeeeeeeeeeeeeed help
Old 06-05-2008, 01:30 PM
theaero theaero is offline
Can you provide us with some more details? Are you using a mac with bootcamp? If so, the profire 2626 is not supported on bootcamp.
Is your unit being recognized by windows XP at all? Right click on my omputer and click manage, then click device manager. Under sound, video, and game controllers it should say M-Audio ProFire 2626 if the drivers are installed (Might also be in the other devices section). Right click this and click properties. There will be a spot that says device status. Does it say the device is working correctly, or does it say the device is not started, or the device is disabled?
Old 06-14-2008, 12:07 PM
thanks For all
my sound card is working perfect now
but I want to know whey the plugins not work ???
i remain
Profire 2626 + Pro Tools rapheal robinson Pro Tools 9 4 09-24-2013 08:13 PM
Profire 2626 + Pro Tools Salivan Pro Tools M-Powered (Win) 3 07-30-2011 11:05 AM
Is it true that M-powered DOES / DOES NOT work with profire 2626 in Boot Camp? herojig Pro Tools M-Powered (Mac) 10 07-06-2010 01:14 PM
pro tools Le 8 With Profire 2626 yungvilleproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-12-2009 08:15 AM
Getting a ProFire 2626 to work on Boot Camp XP? theaero Pro Tools M-Powered (Win) 2 06-16-2008 05:58 PM
