Bug after changing hardware settings - Pro Tools won't start up
I have a new copy of Pro Tools 9.0.0 (thanks very much Digidesign this is my wish come true!) I am using it with a Roland UA 25-EX with ASIO4ALL and it was working but while I was mucking around with latency settings I found an option under Options > Playback where there were two devices listed:
ASIO4ALL UA 25-EX So I thought I'd select the Roland interface to see if I could get an improved latency. Then it said "Pro Tools has to restart to apply the new settings" so I did that but when it restarted it gave me this error message and it gives me this error message each time now, I don't know how to revert it: "Protools hardware is either not installed or is used by another program". How can I set protools to use the ASIO4ALL driver again since it won't load? Is there any way, an ini file or something, or do I have to reinstall Protools? Also do you need more info to log a bug? |
Re: Bug after changing hardware settings - Pro Tools won't start up
It's a bit more serious than I expected. Tried doing a "repair" from the disk but wouldn't work. Then tried doing a full "uninstall" from the disk, restart then a full "install" from the disk. It still doesn't work. Last resort now and it's painful. Reinstall Windoze and then install ASIO4ALL and Protools from scratch. You live and learn I guess, still would be wise for Protools to only display ASIO devices in the Options > Playback menu.
Any other tips such as purging a config file or something would be handy. |
Ok, so I found a neat trick: hold "N" while starting up Pro Tools and it allows you to configure the playback settings! That is cool, case closed.
Were you ever successful in interfacing the UA-25 EX with Pro Tools? or did you only succeed in getting Pro Tools to work again but without the UA-25 EX? Thank you, Peace & Blessings, Joel
thanks bro i was looking for this, was going back in forth between ensemble and 003 board
Pro Tools 7 won't start with Digi 002 rack, hardware not recognized | mtetraul | FireWire & USB Audio Interfaces (Mac) | 3 | 09-02-2013 04:42 AM |
Help pro tools le 8.5 wont start..crashes when loading midi settings | waxxy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-01-2012 10:12 AM |
Settings Changing on Their Own | NJSoundguy | VENUE Live Sound Systems | 5 | 11-14-2011 08:47 AM |
Can't start Pro Tools after another application uses Digidesign hardware | el biciclista | Pro Tools TDM Systems (Mac) | 5 | 10-09-2009 11:49 PM |
Hardware Settings in M-Audio Control Panel and in Pro Tools | SixChurchStreet | Pro Tools M-Powered (Win) | 0 | 02-26-2008 08:30 AM |
