Old 03-25-2022, 02:13 PM
fork-media fork-media is offline
Default firmware update backward compatible?
hi, I'm mid project(s) on a 2012 mac mini- running PT11 and ECON 3.7
its struggling a bit, altho I think I can make it thru,
but I just scored a 2nd hand 2018 6 core and have installed ultimnate on it, as well as EUCON 2021.10.1.29
looking like I got everything going on there plugs etc.
tempted to take the plunge - but to go for it - i need update the firmware on the my artist mix and control.
is that a one way journey?
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 03-26-2022, 01:56 PM
Default Re: firmware update backward compatible?
Not sure if PT11 and EUCON 2021 work together
the EUCON info says somewhat vaguely
"DAW Compatibility
Whilst earlier versions will work, Avid recommends using latest DAW versions.
Avid Pro Tools and Pro Tools | Ultimate 2019.10 or later"
Old 03-28-2022, 09:04 AM
EddieJones's Avatar
PT11 will work but there may be bugs....but going from 3.7 to the latest EUCON will get you so much more. Firmware is down gradable but you likely wont need to as its independent of the software.
Old 03-28-2022, 01:24 PM
thanks Eddie - taken the plunge - yes there are improvements!
( 3.7 was buggy too )
System Upgrade to High Sierra - firmware update backwards compatible to Mavericks? tonwurm macOS 19 12-08-2019 02:58 PM
D-Command Firmware update backwards compatible? inky macOS 4 09-18-2014 01:48 PM
Native card Firmware upgrade. Is it backward compatible? brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 0 11-24-2013 11:44 AM
WAVES 3.5 backward compatible issues jshults Tips & Tricks 1 01-01-2003 01:20 PM
MAC OS 10.2 - not backward compatible with 9.2 Pat Hannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-24-2002 05:30 AM
