Old 03-15-2002, 12:01 AM
mouthdrummer mouthdrummer is offline
Default getting midi into ptLE thru MBOX
so is it possible at all?
im a novice on this.. so can ppl please advise?
i dont mind loading it up through some other input device that goes back into the mbox as a waveform as opposed to a midi. is there such a device?
this is basically the number of inputs for my own usage...
a guitar input, one microphone input, one for keyboards/synths. and thats about it.
but these are too few for a 001 to be worth it and mbox has got only 3. and i dont want to keep on plugging in and out the jacks. my friend is spoiling his second hand 001 coz he thinks thru the combined duration of use of the 2 owners the insides of the thing were loosening, affecting the contacts. at first he thought his cables were the reason, but a check proved it was the contacts within the 001.
so erm.. please help!
thanks.
Pete
Old 03-15-2002, 11:09 AM
DigiTechSupt's Avatar
Default Re: getting midi into ptLE thru MBOX
MBox is not equipped with MIDI ports. Therefore, you will need to purchase a separate MIDI interface to input/output MIDI to/from PT LE.
-As for audio inputs and outputs, MBox is only equipped with two analog inputs. Therefore, you will probably have to do some cable swapping if you want to monitor the audio output of your synth in the session (using an Aux Input).
Brent
Avid Audio Tech Support
Support FAQ
Old 03-16-2002, 09:06 AM
okie...
erm.. i live in Singapore. (South East Asia, at the tip of Malaysian Peninsula.)
any dealers here for digidesign i can ask for help?
or do all digi products here have to be shipped in?
cable swapping... hmm as in jacking in and out?
Old 03-16-2002, 11:42 AM
Avid's Avatar
Avid Avid is offline
Administrator
There are 3 Digidesign dealers in Singapore listed in the Dealer Locator
Administrator
Old 03-17-2002, 01:22 AM
got it... thanks
[img]images/icons/smile.gif[/img]
Yamaha DD55 Midi drum kit and Mbox/PTLE trion12 MIDI 1 05-20-2011 11:43 AM
Stuck midi notes in ptle 6.9 mbox in record only Kurt Riemann 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-04-2005 07:36 AM
New to MIDI Using PTLE With MBox dburrows 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-21-2005 07:17 AM
Recording Midi as Audio with the MBox on PTLE 6.4 CTate MIDI 4 06-09-2004 12:57 PM
MBox/PTLE and MIDI? Jsalam112 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2002 11:19 AM
