Old 05-09-2023, 08:41 AM
gsimonel gsimonel is offline
Default Can't see Mix Bus track in Edit or Mix Window
Please forgive the newbie question. I've opened a new project with, so far, 3 channels--the click track, an imported audio file and a MIDI piano. (There will be more.) I can hear all 3 tracks when I set the output (in the Edit window) to "output >Out L-R (Stereo)>Out 1-2". I couldn't hear anything when I changed the output to "bus > Mix Bus (Stereo)", so I went into Setup>>I/O, clicked on the "bus" tab and then enabled "Mix Bus" by clicking in the gray box, which mapped it to Out L-R. I did not change any other I/O settings. Then I was able to hear sound with the output set to Mix Bus".
Since I'm so new to ProTools, I patted myself on the back for being such a smart boy. But the Mix Bus track has not shown up in either the Edit or Mix windows, like it appears in all templates and the "Fast Start" or "Getting Started" videos that I've watched.
Clearly, I'm not a clever as I thought I was. Eventually, I would like to add compression and limiting to many tracks at once. How do I get the Mix Bus track to appear in my Edit and Mix windows?
Old 05-09-2023, 09:24 AM
smurfyou smurfyou is offline
Default Re: Can't see Mix Bus track in Edit or Mix Window
I'm not familiar with those templates.
But there is no "Mix Bus" track unless you create it. You can have as many as you need but you'll need busses in the IO Setup and separately you'll need to create tracks to route them.
I would unmap what you did.
Then start by making a new stereo track set to "Aux" type. Assign its input to the "Mix Bus" you found. Assign the output to Out 1-2.
~Will
Old 05-13-2023, 10:14 AM
Thank you.
Feature: fix a track in edit window marsian Post - Surround - Video 16 08-06-2022 05:35 PM
Link track selection from edit window to mix window? jaminjamesp Pro Tools 12 7 01-16-2017 05:37 PM
How to adjust Track Width in Edit Window larsongs Getting Started 14 06-16-2014 09:14 PM
Edit Window Track Sizes in v7.3.1 rasta_asia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2007 07:36 AM
Mix/Edit Window Track Selection compmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-12-2000 07:14 AM
