Old 01-21-2004, 10:39 PM
ajp ajp is offline
Default Can\'t Change Volume! Please Help!
I did some volume automation on a part of an audio track to even the volume out for the enitre track. but now when I try to lower the level of the entire track, it won't let me. i.e. the volume is set at +2.5. Each time I try to change the volume, it just slides back to +2.5.
Any suggestions?
Old 01-22-2004, 05:45 AM
where02190 where02190 is offline
Default Re: Can\'t Change Volume! Please Help!
Read the manual regarding automation. If you are in read mode it will not respond to manual changes, you must switch to write or auto latch mode to re record or update the automation.
How come I can't change the volume in the mix window? sb_stefan Pro Tools 10 9 01-28-2020 05:19 PM
How do I pan or change the volume to an exact value? sb_stefan Pro Tools 10 3 02-15-2013 04:51 PM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Why i'm i still getting volume change vudoo Virtual Instruments 1 07-21-2009 01:25 AM
Monitor Volume doesn't change anything... charon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-13-2004 05:39 AM
