Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 12-12-2021, 01:57 PM
Ben Jenssen's Avatar
Default EUControl disables meters on Command|8
I've been thinking I might incorporate Avid Control on my ipad with my Command|8 and UC1. But now I find that turning on 'enable eucon' in 'peripherals' shuts off the meters on my C8. Everything else works fine. Turning off eucon brings back the metering on C8. Any thoughts? Except "get current".
Old 12-14-2021, 09:40 AM
Default Re: EUControl disables meters on Command|8
Pity. I've done what I can to troubleshoot this, but it seems that everything works except the meters on my Command|8, and it means I won't be able to use avid control.
Old 12-14-2021, 09:49 AM
JFreak JFreak is online now
EUCON does not work nicely with legacy DigiDesign/Avid protocols. Yes it is a pity, you need to pick one but cannot mix and match.
Old 12-14-2021, 10:49 AM
So… UF8… Santa?
Old 12-15-2021, 01:38 PM
smurfyou smurfyou is offline
So… UF8… Santa?
The UF8 will also have problems if Eucon is enabled.
~Will
Command 8 LED meters are dead Ben Jenssen ProControl, Control|24, Command|8 7 08-09-2021 02:23 PM
S1 Eucontrol soft key command ordering issue Finnmaker Avid S1, S3, Dock and Control App 1 04-16-2020 11:52 AM
Command 8 - Meters Not Showing in 2018.7 Siegfried Meier Pro Tools 2018 7 03-16-2019 10:12 AM
Eucontrol 3.3 software causes meters to stop working. jonmichaels74 Artist Series 2 08-06-2015 03:57 PM
OSX "Hide Others" command disables Touchscreen EdgarRothermich Artist Series 0 12-05-2012 10:10 PM
