USD dosen\'t generate time code when in 9 pin remote mode
Why is it that I can't generate time code from the USD when the 9 pin is enabled?? I would like to stripe a tape while I record onto it at the same time I'm wartching the picture and the only way to do it is by disabling the 9 pin. Why ?????
Re: USD dosen\'t generate time code when in 9 pin remote mode
Actually, the video would have the time code but I would want to dump the mix onto a DA-88 but not stripe the tape before hand. I would like to stripe the DA-88 as I watch the picture. I guess I could 'Y' off the LTC on the video deck but just wondered why you couldn't use the USD for generating code.
In a standard Machine Control configuration you'd have LTC from the deck coming back into the USD. If there's no code on the tape (yet), there is no way for Pro Tools to get positional reference.
-If Pro Tools is set to "generate timecode using USD", it can't do this AND simultaneously read incoming timecode...It's one or the other. Brent |
Upon further research I must amend my last statement. Although the USD cannot receive and generate LTC, it does have a LTC Regeneration mode (subtle difference, I know).
-The USD will regenerate LTC whenever the external positional reference is moving at normal forward speed. -Setup for regenerating LTC is explained in the USD manual (around page 46, depending on your manual version). Brent |
Midi Time code freewheels in loop mode | mtbf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-06-2010 09:36 AM |
USD does not generate time code in OS9, but works fine in OSX | John_Toolbox | Digidesign Hardware & Software | 2 | 04-27-2009 11:40 AM |
Generate Time Code | Branko | ICON & C|24 | 1 | 01-20-2009 12:00 PM |
Generate Time Code without SYNC I/O | bgh930 | Pro Tools TDM Systems (Mac) | 8 | 07-10-2006 08:26 AM |
USD-cant generate time code when ref. to video? | Jkrupp | Pro Tools TDM Systems (Mac) | 3 | 06-11-2001 05:25 AM |
