Importing Video
When importing video into Pro Tools, it doesn't save the video file in the Pro Tools session folder, so if I move to another studio the video is missing, I can't find anywhere in the prefs that says import video, the only work around I can think of is to 'save copy in' but surely that isn't what we must do...
Also when working with videos, is there ever any need to into more detail than 1 frame? Video doesn't move in sub-frames does it, only frames? |
Re: Importing Video
save a copy as will give you the option to bundle everything together. You'll want to keep your video files on a separate drive for better performance.
Re: Importing Video
What about when moving between studios? this makes it so easy to forget a video file or files.
Also I'm failing to see the need of editing in more detail than 1 frame at a time, which leads me onto this question, when editing sound for a video, should we work in frames or samples? One more thing, the video is 24.97 fps and so the video frames aren't quite lining up with grid lines when in timebase mode. |
Re: Importing Video
24.97? I think you better tell us more about the project, I'll assume it's a European thing.
Picture is in whole frames, less than a frame would look like a glitch when played. We usually work between 1 frame and 1/4 frame grid at my place
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Re: Importing Video
Most likely a typo.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Importing Video
The video is an AVI, when imported into Pro Tools the video is coming up as 24.97 which means the frames don't line up with the grid.
Why this is happening I have no idea. Also Craig, how come you work with 1/4 frames, is that for moving the audio into place? or something else? |
Re: Importing Video
Check your Project window to see where all of your media is before moving from one studio to another. The function "Copy and relink" is very useful when cleaning up. |
Re: Importing Video
you should talk with your editor to confirm the timecode spec. I would assume there is an error in the export given that frame rate. Tell the editor you need this fixed as nothing good will come of it. Best case scenario is that it won't matter but more than likely it will.
Work in frames. I usually start out with 5 frames on the large nudge keys and one frame on the smaller nudge keys and as the mix progresses or if more precision is required for editing I switch to 1/4 frames. When moving a project between rooms, "File/Save A Copy As" will transfer all assets into one folder for you. When you transfer rooms, you load that folder and for best results, move the video file to a separate drive than the audio assets. I usually use a transfer drive to shuttle between rooms. Or if you're networked you can use a drop box depending on how large the session is. |
Re: Importing Video
Why not just copy the quicktime from the workspace of either your mac or windows? I do all of my moving of quicktimes outside of PT, then relink. Makes for a lot less mess.
No, video tracks, due their nature, works frame by frame. As far as editing the actual sound, you do what ever sounds right! For me, that means, other than doing Confo's, just stay in slip mode. Think dialog. If you restrict yourself to cutting only on the frame edge, and have to replace a syllable, it will sound completely off.
We, in post sound, are illusionists, not magicians. |
Importing HD Video 16:9 going to 4:3 | twix | Pro Tools 10 | 7 | 01-31-2014 02:57 PM |
importing video | jackieb63 | macOS | 1 | 01-28-2011 09:01 AM |
importing video into PT | MrRippie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-26-2009 01:20 PM |
importing HD video into LE for a music video | tonejunkee | Post - Surround - Video | 4 | 03-19-2008 11:33 AM |
Importing from DV video | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-18-2003 06:47 PM |
